[postgis-users] Associate CopyTopology Schema with TopoGeometry
Matt Kenny matthewkenny at gmail.com
Fri Jan 3 14:07:41 PST 2014
Hello,
I've created a series of topology schemas, copied using the `CopyToplolgy`
function [1].
These schemas are not, by default, associated with any particular
layer/TopoGeometry. This can be seen in the contents of the layer table [2].
So, I'm wondering if it is possible to do one of the following:
- Create a new column of type topogeometry, and associate it with any of
these currently unassociated schemas.
- Modify an existing topogeometry column (in my example,
somalia_admin1s.topogeoms)
Thanks,
Matt
1: http://postgis.net/docs/CopyTopology.html
2: https://gist.github.com/mattmakesmaps/45fe32931cacdf40d107
m a t t h e w k e n n y
http://mattmakesmaps.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140103/7601a4c6/attachment.html>
