[postgis-users] Issues with pgrouting workshop code in postgis 2.11/pgrouting 2.0
    Emmanuel Adegboye
    eaadegboye at googlemail.com
    Sat Jan  4 13:20:31 PST 2014
Hello Daniel.
Thanks for your response.
I will take a look at the workshop again but I got stuck at some point
trying to write wrapper functions. I will post questions if I get stuck,
your answers would be invaluable.
Regards,
Emmanuel Adegboye
On 4 January 2014 04:38, Daniel Kastl <daniel at georepublic.de> wrote:
> Hi Emmanuel,
> The workshop code you're posting is not the current one anymore and won't
> work anymore with pgRouting 2.0.
> If you want to use the "old" PHP function, then you need to modify it:
> * Write your own plpgsql wrapper function. You can take a look at the
> examples in the new workshop:
> http://workshop.pgrouting.org/chapters/wrapper.html
> * Change the function name, arguments, etc. according to your custom
> function in the PHP script.
> Daniel
> On Sat, Jan 4, 2014 at 6:43 AM, Emmanuel Adegboye <
> eaadegboye at googlemail.com> wrote:
>> I'm having issues getting the pgrouting workshop to work on Postgresql
>> 9.2/PostGIS 2.11 and pgrouting 2.0 on windows.
>> How can I rewrite the following php/sql code and make it compatible with
>> my version:
>> <?php
>>   // Database connection settings
>>   define("PG_DB"  , "routing");
>>   define("PG_HOST", "localhost");
>>   define("PG_USER", "postgres");
>>   define("PG_PORT", "5432");
>>    define("PG_PASSWD",   "*******");
>>   define("TABLE",   "eastlegon");
>>   $counter = $pathlength = 0;
>>   // Retrieve start point
>>   $start = split(' ',$_REQUEST['startpoint']);
>>   $startPoint = array($start[0], $start[1]);
>>   // Retrieve end point
>>   $end = split(' ',$_REQUEST['finalpoint']);
>>   $endPoint = array($end[0], $end[1]);
>>   // Find the nearest edge
>>   $startEdge = findNearestEdge($startPoint);
>>   $endEdge   = findNearestEdge($endPoint);
>>   // FUNCTION findNearestEdge
>>   function findNearestEdge($lonlat) {
>>     // Connect to database
>>     $con = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER." password=".PG_PASSWD);
>>     $sql = "SELECT gid, source, target, the_geom,
>>              distance(the_geom, GeometryFromText(
>>                   'POINT(".$lonlat[0]." ".$lonlat[1].")', 4326)) AS dist
>>             FROM ".TABLE."
>>             WHERE the_geom && setsrid(
>>                   'BOX3D(".($lonlat[0]-200)."
>>                          ".($lonlat[1]-200).",
>>                          ".($lonlat[0]+200)."
>>                          ".($lonlat[1]+200).")'::box3d, 4326)
>>             ORDER BY dist LIMIT 1";
>>     $query = pg_query($con,$sql);
>>     $edge['gid']      = pg_fetch_result($query, 0, 0);
>>     $edge['source']   = pg_fetch_result($query, 0, 1);
>>     $edge['target']   = pg_fetch_result($query, 0, 2);
>>     $edge['the_geom'] = pg_fetch_result($query, 0, 3);
>>     // Close database connection
>>     pg_close($con);
>>     return $edge;
>>   // Select the routing algorithm
>>   switch($_REQUEST['method']) {
>>     case 'SPD' : // Shortest Path Dijkstra
>>       $sql = "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
>>                    length(rt.the_geom) AS length, ".TABLE.".id
>>                 FROM ".TABLE.",
>>                     (SELECT gid, the_geom
>>                         FROM dijkstra_sp_delta(
>>                             '".TABLE."',
>>                             ".$startEdge['source'].",
>>                             ".$endEdge['target'].",
>>                             3000)
>>                      ) as rt
>>                 WHERE ".TABLE.".gid=rt.gid;";
>>       break;
>>     case 'SPA' : // Shortest Path A*
>>                   FROM ".TABLE.",
>>                           FROM astar_sp_delta(
>>                               '".TABLE."',
>>                               3000)
>>                        ) as rt
>>       break;
>>     case 'SPS' : // Shortest Path Shooting*
>>                   FROM ".TABLE.",
>>                           FROM shootingstar_sp(
>>                               '".TABLE."',
>>                               ".$startEdge['gid'].",
>>                               ".$endEdge['gid'].",
>>                               3000, 'length', false, false)
>>                        ) as rt
>>       break;
>>   } // close switch
>>   // Database connection and query
>>   $dbcon = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER." password=".PG_PASSWD);
>>   $query = pg_query($dbcon,$sql);
>>   // Return route as XML
>>   $xml  = '<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>'."\n";
>>   $xml .= "<route>\n";
>>   // Add edges to XML file
>>   while($edge=pg_fetch_assoc($query)) {
>>     $pathlength += $edge['length'];
>>     $xml .= "\t<edge id='".++$counter."'>\n";
>>     $xml .= "\t\t<id>".$edge['id']."</id>\n";
>>     $xml .= "\t\t<wkt>".$edge['wkt']."</wkt>\n";
>>     $xml .= "\t\t<length>".round(($pathlength/1000),3)."</length>\n";
>>     $xml .= "\t</edge>\n";
>>   $xml .= "</route>\n";
>>   pg_close($dbcon);
>>   // Return routing result
>>   header('Content-type: text/xml',true);
>>   echo $xml;
>> Thanks,
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140104/11f8fca5/attachment.html>
