[postgis-users] Associate CopyTopology Schema with TopoGeometry
Sandro Santilli
strk at keybit.net
Mon Jan 6 07:45:13 PST 2014
See previous discussion here: http://trac.osgeo.org/postgis/ticket/1195
Your input is welcome.
--strk;
On Fri, Jan 03, 2014 at 02:07:41PM -0800, Matt Kenny wrote:
> Hello,
> I've created a series of topology schemas, copied using the `CopyToplolgy`
> function [1].
> These schemas are not, by default, associated with any particular
> layer/TopoGeometry. This can be seen in the contents of the layer table [2].
> So, I'm wondering if it is possible to do one of the following:
> - Create a new column of type topogeometry, and associate it with any of
> these currently unassociated schemas.
> - Modify an existing topogeometry column (in my example,
> somalia_admin1s.topogeoms)
> Thanks,
> Matt
> 1: http://postgis.net/docs/CopyTopology.html
> 2: https://gist.github.com/mattmakesmaps/45fe32931cacdf40d107
> m a t t h e w k e n n y
> http://mattmakesmaps.com
