[postgis-users] Issues with pgrouting workshop code in postgis 2.11/pgrouting 2.0
Emmanuel Adegboye eaadegboye at googlemail.com
Thu Jan 9 07:06:06 PST 2014
Hi Stephen.
Thanks for your response.
I tried running thr pgr_fromAtoB wrapper function in pgAdmin and I
initially get an error:
> ERROR: relation "vertices_tmp" does not exist
> SQL state: 42P01
> Context: PL/pgSQL function pgr_fromatob(character varying,double
> precision,double precision,double precision,double precision) line 11 at
> EXECUTE statement
Then I changed the table name in the sql code to eastlegon_vertices_pgr.
This is the table that stores the vertices and I assume that's the one been
referred to. This returns a message "Query returned successfully with no
result in 111 ms."
I saved this query as sql and tried installing in psql but I get the error:
> C:\Users\GWU>psql -U postgres -d routing -f
> C:\Users\GWU\Desktop\HGT\wrapper3.sq
> l
> Password for user postgres:
> psql:C:/Users/GWU/Desktop/HGT/wrapper3.sql:79: ERROR:  syntax error at or
> near "
> LINE 1:
Why does the query run but fail to install?
Following also to the SQL view parameters (Geoserver) part of the workshop,
I got to the part of changing the validation regular expression but once I
hit refresh on the Attributes list, I don't get any attribute. Instead, I
get an error in geoserver:
   - ERROR: column "’eastlegon’" does not exist Position: 84
This is the part where i get stuck. I really appreciate your help so far.
I'm sure there's something I'm probably missing but I need your advise.
Regards,
Emmanuel
On Jan 9, 2014 2:48 PM, "Stephen Woodbridge" <woodbri at swoodbridge.com>
wrote:
> So looks like progress. Now you need to post what failed to run and what
> the errors were. Also it sounds like pgRouting is working ok since you can
> display things in qgis so the problem at thispoint sounds more like
> JavaScript issues or issues with OpenLayers configuration.
> Are you using FireFox and Firebug? With that you can see your exact ajax
> requests and responses.
> -Steve
> On 1/9/2014 4:49 AM, Emmanuel Adegboye wrote:
>> Hello.
>> I'm now working with the 2013 workshop now and I have my tables
>> structured as follows:
>> routing=# \d
>>                        List of relations
>>   Schema |             Name              |   Type   |  Owner
>>   public | eastlegon                     | table    | postgres
>>   public | eastlegon_gid_seq             | sequence | postgres
>>   public | eastlegon_vertices_pgr        | table    | postgres
>>   public | eastlegon_vertices_pgr_id_seq | sequence | postgres
>>   public | eastlegonboundary             | table    | postgres
>>   public | eastlegonboundary_gid_seq     | sequence | postgres
>>   public | geography_columns             | view     | postgres
>>   public | geometry_columns              | view     | postgres
>>   public | raster_columns                | view     | postgres
>>   public | raster_overviews              | view     | postgres
>>   public | route                         | table    | postgres
>>   public | spatial_ref_sys               | table    | postgres
>> (12 rows)
>> routing=# \d eastlegon
>>                                        Table "public.eastlegon"
>>      Column    |           Type            |
>>   Modifiers
>>   gid          | integer                   | not null default
>> nextval('eastlegon_
>> gid_seq'::regclass)
>>   length       | double precision          |
>>   class_id     | integer                   | not null
>>   postcode     | character varying(254)    |
>>   name         | character varying(100)    |
>>   the_geom     | geometry(LineString,4326) |
>>   source       | integer                   |
>>   target       | integer                   |
>>   cost_len     | double precision          |
>>   cost_time    | double precision          |
>>   rcost_len    | double precision          |
>>   rcost_time   | double precision          |
>>   x1           | double precision          |
>>   y1           | double precision          |
>>   x2           | double precision          |
>>   y2           | double precision          |
>>   to_cost      | double precision          |
>>   rule         | text                      |
>>   isolated     | integer                   |
>>   reverse_cost | double precision          |
>> Indexes:
>>      "eastlegon_pkey" PRIMARY KEY, btree (gid)
>>      "eastlegon_source_idx" btree (source)
>>      "eastlegon_target_idx" btree (target)
>>      "eastlegon_the_geom_gidx" gist (the_geom)
>>      "source_idx" btree (source)
>>      "target_idx" btree (target)
>> My aim is simply to follow the workshop and display my routes using at
>> least dijkstra algorithm in openlayers 2 (or 3 if it's not too
>> complicated). I try installing the wrappers in the workshop but I get
>> syntax errors.
>> I'm sure my routing is properly set up since I can display routes using
>> the pgRouting layer plugin for QGIS. I also have the layer stored
>> properly in Geoserver. I can already display the layers as a WMS layer
>> using openlayers. My only challenge is to display the route dynamically
>> in a web browser.
>> I need pointers in the right direction. My skills are still basic
>> though, but I'm willing to learn.
>> Thanks a lot for your help.
>> Emmanuel
>> On 4 January 2014 22:20, Emmanuel Adegboye <eaadegboye at googlemail.com
>> <mailto:eaadegboye at googlemail.com>> wrote:
>>     Hello Daniel.
>>     I will take a look at the workshop again but I got stuck at some
>>     point trying to write wrapper functions. I will post questions if I
>>     get stuck, your answers would be invaluable.
>>     Regards,
>>     Emmanuel Adegboye
>>     On 4 January 2014 04:38, Daniel Kastl <daniel at georepublic.de
>>     <mailto:daniel at georepublic.de>> wrote:
>>         Hi Emmanuel,
>>         The workshop code you're posting is not the current one anymore
>>         and won't work anymore with pgRouting 2.0.
>>         If you want to use the "old" PHP function, then you need to
>>         modify it:
>>         * Write your own plpgsql wrapper function. You can take a look
>>         at the examples in the new workshop:
>>         http://workshop.pgrouting.org/chapters/wrapper.html
>>         * Change the function name, arguments, etc. according to your
>>         custom function in the PHP script.
>>         Daniel
>>         On Sat, Jan 4, 2014 at 6:43 AM, Emmanuel Adegboye
>>         <eaadegboye at googlemail.com <mailto:eaadegboye at googlemail.com>>
>>         wrote:
>>             I'm having issues getting the pgrouting workshop to work on
>>             Postgresql 9.2/PostGIS 2.11 and pgrouting 2.0 on windows.
>>             How can I rewrite the following php/sql code and make it
>>             compatible with my version:
>>             |<?php
>>                // Database connection settings
>>                define("PG_DB"   ,  "routing");
>>                define("PG_HOST",  "localhost");
>>                define("PG_USER",  "postgres");
>>                define("PG_PORT",  "5432");
>>                 define("PG_PASSWD",    "*******");
>>                define("TABLE",    "eastlegon");
>>                $counter=  $pathlength=  0;
>>                // Retrieve start point
>>                $start=  split('',$_REQUEST['startpoint']);
>>                $startPoint=  array($start[0],  $start[1]);
>>                // Retrieve end point
>>                $end=  split('',$_REQUEST['finalpoint']);
>>                $endPoint=  array($end[0],  $end[1]);
>>                // Find the nearest edge
>>                $startEdge=  findNearestEdge($startPoint);
>>                $endEdge=  findNearestEdge($endPoint);
>>                // FUNCTION findNearestEdge
>>                function  findNearestEdge($lonlat)  {
>>                  // Connect to database
>>                  $con=  pg_connect("dbname=".PG_DB." host=".PG_HOST."
>> user=".PG_USER." password=".PG_PASSWD);
>>                  $sql=  "SELECT gid, source, target, the_geom,
>>                           distance(the_geom, GeometryFromText(
>>                                'POINT(".$lonlat[0]."".$lonlat[1].")',
>> 4326)) AS dist
>>                          FROM ".TABLE."
>>                          WHERE the_geom && setsrid(
>>                                'BOX3D(".($lonlat[0]-200)."
>>                                       ".($lonlat[1]-200).",
>>                                       ".($lonlat[0]+200)."
>>                                       ".($lonlat[1]+200).")'::box3d, 4326)
>>                          ORDER BY dist LIMIT 1";
>>                  $query=  pg_query($con,$sql);
>>                  $edge['gid']       =  pg_fetch_result($query,  0,  0);
>>                  $edge['source']    =  pg_fetch_result($query,  0,  1);
>>                  $edge['target']    =  pg_fetch_result($query,  0,  2);
>>                  $edge['the_geom']  =  pg_fetch_result($query,  0,  3);
>>                  // Close database connection
>>                  pg_close($con);
>>                  return  $edge;
>>                // Select the routing algorithm
>>                switch($_REQUEST['method'])  {
>>                  case  'SPD'  :  // Shortest Path Dijkstra
>>                    $sql=  "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
>>                                 length(rt.the_geom) AS length,
>> ".TABLE.".id
>>                              FROM ".TABLE.",
>>                                  (SELECT gid, the_geom
>>                                      FROM dijkstra_sp_delta(
>>                                          '".TABLE."',
>>                                          ".$startEdge['source'].",
>>                                          ".$endEdge['target'].",
>>                                          3000)
>>                                   ) as rt
>>                              WHERE ".TABLE.".gid=rt.gid;";
>>                    break;
>>                  case  'SPA'  :  // Shortest Path A*
>> ".TABLE.".id
>>                                FROM ".TABLE.",
>>                                        FROM astar_sp_delta(
>>                                            '".TABLE."',
>>                                            3000)
>>                                     ) as rt
>>                    break;
>>                  case  'SPS'  :  // Shortest Path Shooting*
>> ".TABLE.".id
>>                                FROM ".TABLE.",
>>                                        FROM shootingstar_sp(
>>                                            '".TABLE."',
>>                                            ".$startEdge['gid'].",
>>                                            ".$endEdge['gid'].",
>>                                            3000, 'length', false, false)
>>                                     ) as rt
>>                    break;
>>                }  // close switch
>>                // Database connection and query
>>                $dbcon=  pg_connect("dbname=".PG_DB." host=".PG_HOST."
>>                $query=  pg_query($dbcon,$sql);
>>                // Return route as XML
>>                $xml=  '<?xml version="1.0" encoding="UTF-8"
>> standalone="yes"?>'."\n";
>>                $xml .= "<route>\n";
>>                // Add edges to XML file
>>                while($edge=pg_fetch_assoc($query)) {
>>                  $pathlength += $edge['length'];
>>                  $xml .= "\t<edge  id='".++$counter."'>\n";
>>                  $xml .= "\t\t<id>".$edge['id']."</id>\n";
>>                  $xml .= "\t\t<wkt>".$edge['wkt']."</wkt>\n";
>>                  $xml .= "\t\t<length>".round(($
>> pathlength/1000),3)."</length>\n";
>>                  $xml .= "\t</edge>\n";
>>                $xml .= "</route>\n";
>>                pg_close($dbcon);
>>                // Return routing result
>>                header('Content-type: text/xml',true);
>>                echo $xml;
>>             Thanks,
>>             _______________________________________________
>>             postgis-users mailing list
>>             postgis-users at lists.osgeo.org
>>             <mailto:postgis-users at lists.osgeo.org>
>>             http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>         Georepublic UG & Georepublic Japan
>>         eMail: daniel.kastl at georepublic.de
>>         <mailto:daniel.kastl at georepublic.de>
>>         Web: http://georepublic.de <http://georepublic.de/>
>>         postgis-users at lists.osgeo.org <mailto:postgis-users at lists.
>> osgeo.org>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140109/2505fb29/attachment.html>
