[postgis-users] Look for Help on Libraries and Dependencies for Compiling Postgis2.1 Source for Suse 11 SP3
Bborie Park dustymugs at gmail.com
Thu Jan 16 09:57:04 PST 2014
And SP2 does not have gdal-dev packages? I suggest you compile gdal
yourself with what formats you need. It's not that bad to compile,
especially since you're compiling everything else.
-bborie
On Jan 16, 2014 9:54 AM, "Marco" <marco91414 at gmail.com> wrote:
> Hi Bborie,
> There is no gdal in 11 SP3 in OpenSUSE repo that I can find, but I am
> using the gdal from 11 SP 2 repo.
> Thanks
> On Wed, Jan 15, 2014 at 7:44 PM, Bborie Park <dustymugs at gmail.com> wrote:
>> Are you using GDAL provided by OpenSUSE? Or did you compile your own?
>> -bborie
>> On Wed, Jan 15, 2014 at 7:25 PM, Marco <marco91414 at gmail.com> wrote:
>>> Hi,
>>> I am trying to build postgis 2.1 from the source for SUSE 11 SP 3.
>>> However it requires openjp2, hdf5, mfhdf, df (all devel version I think)
>>> that I could not find. I have tried few repositories such as Opensuse,
>>> Packman and the Suse repo from Zypper.
>>> I would really appreciate if anyone could tell me about other approaches
>>> of finding these libraries.
>>> Here is the error message from the terminal when I try to compile the
>>> source.
>>> /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld:
>>> cannot find -lopenjp2
>>> cannot find -lhdf5
>>> cannot find -lmfhdf
>>> cannot find -ldf
>>> collect2: ld returned 1 exit status
>>> make[2]: *** [raster2pgsql] Error 1
>>> make[2]: Leaving directory
>>> `/home/ekeemaa/IPT_NMS/postgis/postgis-2.1.1/raster/loader'
>>> make[1]: *** [rtloader] Error 2
>>> make[1]: Leaving directory
>>> `/home/ekeemaa/IPT_NMS/postgis/postgis-2.1.1/raster’
>>> make: *** [all] Error 1
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140116/a11d4827/attachment.html>
