[postgis-users] Look for Help on Libraries and Dependencies for Compiling Postgis2.1 Source for Suse 11 SP3
    Bborie Park
    dustymugs at gmail.com
    Thu Jan 16 10:05:11 PST 2014
No. Your gdal-dev is more than likely fine. It's the dev packages that the
gdal-dev packages that are missing. If you can't find those hdf5, openjp2
dev packages, you'll probably want to compile gdal.
-bborie
On Jan 16, 2014 10:01 AM, "Marco" <marco91414 at gmail.com> wrote:
> Hi,
> I am using libgdal-devel-1.10.1-1.4. Do you think all the complains of
> missing libraries like openjp2, hdf5 etc. are related to gdal-dev package?
> Thanks
> On Thu, Jan 16, 2014 at 9:57 AM, Bborie Park <dustymugs at gmail.com> wrote:
>> And SP2 does not have gdal-dev packages? I suggest you compile gdal
>> yourself with what formats you need. It's not that bad to compile,
>> especially since you're compiling everything else.
>> -bborie
>> On Jan 16, 2014 9:54 AM, "Marco" <marco91414 at gmail.com> wrote:
>>> Hi Bborie,
>>> There is no gdal in 11 SP3 in OpenSUSE repo that I can find, but I am
>>> using the gdal from 11 SP 2 repo.
>>> Thanks
>>> On Wed, Jan 15, 2014 at 7:44 PM, Bborie Park <dustymugs at gmail.com>wrote:
>>>> Are you using GDAL provided by OpenSUSE? Or did you compile your own?
>>>> -bborie
>>>> On Wed, Jan 15, 2014 at 7:25 PM, Marco <marco91414 at gmail.com> wrote:
>>>>> Hi,
>>>>> I am trying to build postgis 2.1 from the source for SUSE 11 SP 3.
>>>>> However it requires openjp2, hdf5, mfhdf, df (all devel version I think)
>>>>> that I could not find. I have tried few repositories such as Opensuse,
>>>>> Packman and the Suse repo from Zypper.
>>>>> I would really appreciate if anyone could tell me about other
>>>>> approaches of finding these libraries.
>>>>> Here is the error message from the terminal when I try to compile the
>>>>> source.
>>>>> /usr/lib64/gcc/x86_64-suse-linux/4.3/../../../../x86_64-suse-linux/bin/ld:
>>>>> cannot find -lopenjp2
>>>>> cannot find -lhdf5
>>>>> cannot find -lmfhdf
>>>>> cannot find -ldf
>>>>> collect2: ld returned 1 exit status
>>>>> make[2]: *** [raster2pgsql] Error 1
>>>>> make[2]: Leaving directory
>>>>> `/home/ekeemaa/IPT_NMS/postgis/postgis-2.1.1/raster/loader'
>>>>> make[1]: *** [rtloader] Error 2
>>>>> make[1]: Leaving directory
>>>>> `/home/ekeemaa/IPT_NMS/postgis/postgis-2.1.1/raster’
>>>>> make: *** [all] Error 1
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140116/7cd9b4c8/attachment.html>
