[postgis-users] Rép: Re: Removing tiny polygons
Hugues François hugues.francois at irstea.fr
Mon Jan 27 22:31:52 PST 2014
Hello,
In your case, ST_GeometryType() really returns `ST_Polygon' ?
You can have a table with several rows, each one containing a geometry. This geometry can ne a simple one (single entity) or a multi one.
Hugues
Tom McCallum <termcc at googlemail.com> a écrit :
Ok, really silly question now, how can a polygon field contain what looks
like multiple polygons.
So I have a Shapefile of GB but its only got 3 polygons in, according to
PostGis, but there are lots of small island polygons as well which are not
attached to any of the main land masses, so I don't see how they can all
be one polygon?  Can a polygon field have multiple polygons in without
being a multi-polygon?
Thanks
On Mon, 27 Jan 2014 19:15:18 -0000, Morten Sickel <morten at sickel.net>
wrote:
> It depends on what you mean with "remove" - do you want to just have the
> large polygons without the area that is covered by the small ones or do
> you want to add the area of the small polygons onto one or more of the
> larges? (e.g. how one typically wants to handle shiver polygons)
> In the first case it is as easy as a query like
> select the_geom where ST_area(the_geom) > ...
> Morten
> Tom McCallum skrev:
>> Hi all,
>> If I have a polygon geometry field which seems to be made up of a large
>> number of tiny polygons and some larger ones, what is the best way to
>> remove polygons below a certain size?  Would I need to preprocess this
>> and
>> save in a new table/record or can I dynamically do it?
>> Thanks
>> Tom
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
