[postgis-users] QGis 2.0 Copy/Paste from shapefile to Postgis issue if the primary key is a string
F T
oukile at gmail.com
Fri Jan 31 06:02:45 PST 2014
Hello
We have a pb with copy/paste from a shapefile to postgis if the primary key
is a string.
The primary key is left NULL and no commit is possible.
To reproduce the pb :
Create *table1 *with a string primary key
> CREATE TABLE table1
> f1 character varying(10) NOT NULL,
> f2 character varying(10),
> geom geometry,
> *CONSTRAINT t1_pkey PRIMARY KEY (f1),*
> CONSTRAINT enforce_dims_geom CHECK (st_ndims(geom) = 2),
> CONSTRAINT enforce_geotype_geom CHECK (geometrytype(geom) =
> 'POINT'::text),
> CONSTRAINT enforce_srid_geom CHECK (st_srid(geom) = 2154)
*table2* is the same as table 1 but it has no primary key
> CREATE TABLE table2
> geom geometry,
> 'POINT'::text),
*shapes.shp* is a shapefile that contains the points I would like to
copy/paste in the Postgis tables
(see attached zip file)
1) if I copy/paste the points from shapes.shp to table1, the key field
stays NULL and the commit is impossible.
2) if I copy/paste the points from shapes.shp to table2, everything is ok.
Have you ever seen this bug?
Thanks
Fabrice
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140131/8b76c6c5/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140131/8b76c6c5/attachment.zip>
