[postgis-users] Odd Behavior with ST_Intersects (PostGIS 2.1, Ubuntu 12.04)
Jerry Sievert
jerry at legitimatesounding.com
Fri Jan 31 15:24:49 PST 2014
Hello,
I am using Ubuntu 12.04 with the official PostgreSQL apt repo (via
https://wiki.postgresql.org/wiki/Apt). I am running into an easily
reproducible issue, and was hoping for some help to solve this.
When using ST_Intersects() not all rows that intersect are returned. This
was not the case in previous versions that we have upgraded from.
These are the steps to reproduce on a fresh install of Ubuntu 12.04 with
all packages updated and PostGIS/PostgreSQL 9.3 installed:
test=# CREATE TABLE test (id serial, condition_geo geography);
CREATE TABLE
test=# INSERT INTO test (condition_geo) VALUES
(ST_Buffer(ST_GeogFromWKB(ST_MakePoint(20.0,30.0)),10.0));
INSERT 0 1
test=# SELECT id FROM test WHERE ST_Intersects("condition_geo",
ST_Buffer(ST_GeogFromText('POINT(20.0 30.0)'), 20.0)) IS TRUE;
id
1
(1 row)
INSERT 0 1
id
1
(1 row)
ST_Buffer(ST_GeogFromText('POINT(20.0 30.0)'), 20.0)) IS TRUE AND id = 2;
id
2
(1 row)
Note that the SELECT should return both rows 1 and 2 in the first SELECT.
Any thoughts?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140131/e3a9df21/attachment.html>
