[postgis-users] Reference vrt datasets in postgis raster
Christian Yrrman
yrrman at gmail.com
Fri Jul 11 07:33:05 PDT 2014
Hi All,
I'm a newbie to this group, so hello everyone and thanks in advance for
letting me participate :-)
After several tests and searching on the net I'm a little stuck with the
following problem:
I have downloaded a bunch of MODIS tiles (MOD13A1) from [0] that I want to
(only) reference in a postgis raster database. These tiles come in hdf
containers with several layers in it
- For a start, I'm only interested in the EVI layer, so I created EVI vrt
files with command [1]
- This gives me several EVI*.vrt files referencing EVI with the original
sinusoidal projection. According to spatialreference.org, the closest SRS
match is sr-org6974 [2].
- As this is not in postgis, I've imported this into spatial_ref_sys [3]
- Next, I'm using the following command to insert the data into raster
table "modistest" with the following command:
for i in `find / -name "EVI_origSRS*.vrt"`; do
raster2pgsql -s 96974 -R -F -f rast -a $i modistest;
done
where:
"-s 96974" - use the freshly imported MODIS SRS from [2]
-R Register the raster as an out-of-db (filesystem) raster. Provided
raster should have absolute path to the file
-F Add a column with the filename of the raster.
-f <column> Specify the name of the raster column
-a Appends raster into current table, must be
exactly the same table schema.
I've built the index on rast in a separate step (not using switch -I)
This populates table modistest (using | psql...), so it looks fine. However
when I want to retrieve data from the raster, e.g. via
SELECT ST_AsTiff(rast) from public.modistest where id=1158;
I get an error message like this
ERROR: rt_raster_from_gdal_dataset: Unable to get data from transformed
raster
CONTEXT: PL/pgSQL function "st_astiff" line 20 at RETURN
and in the postgresql log I get
ERROR 4:
`HDF4_EOS:EOS_GRID:"MOD13A1.A2012065.h35v10.005.2012082112322.hdf":MODIS_Grid_16DAY_500m_VI:500m
16 days EVI' does not exist in the file system,
and is not recognised as a supported dataset name.
So it looks like the layers were not correctly referenced - however I
cannot see a mistake. I'm actually using "find / -name "EVI_origSRS*.vrt"
to get the full path for the loop (not "for i in *vrt")
Any help/advice is highly appreciated! In a next step, I would even like to
transform the sinusoidal tile afterwards with ST_transform to epsg:4326.
That would be fantastic, I'd have all tiles in original format in the file
system and let postgis do all the rest.. :-)
Thanks in advance and greetings!
Chris
[0] MODIS download website
http://e4ftl01.cr.usgs.gov/MOLT/MOD13A1.005/
[1] command to create vrt files:
#!/bin/bash
for i in *hdf; do
echo Processing $i
j=`gdalinfo $i| grep SUBDATASET_2_NAME | cut -d '=' -f 2`
echo Extracted $j
gdal_translate -of VRT "$j" EVI_origSRS_$i.vrt
done
[2] SRS projeciton for MODIS
http://spatialreference.org/ref/sr-org/6974/
[3] SQL command to insert MODIS SRS
INSERT into spatial_ref_sys (srid, auth_name, auth_srid, proj4text, srtext)
values ( 96974, 'sr-org', 6974, '+proj=sinu +lon_0=0 +x_0=0 +y_0=0
+ellps=WGS84 +datum=WGS84 +units=m +no_defs ',
'PROJCS["MODIS Sinusoidal",
GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],
PROJECTION["Sinusoidal"],
PARAMETER["false_easting",0.0],
PARAMETER["false_northing",0.0],
PARAMETER["central_meridian",0.0],
PARAMETER["semi_major",6371007.181],
PARAMETER["semi_minor",6371007.181],
UNIT["m",1.0],AUTHORITY["SR-ORG","6974"]]');
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140711/40de8e79/attachment.html>
