[postgis-users] Reference vrt datasets in postgis raster
Christian Yrrman
yrrman at gmail.com
Sun Jul 27 06:06:57 PDT 2014
Hi All,
with regard to the problem of referencing vrt raster of hdf-containers as
out-of-db-rasters in postgis (see thread), I found the solution:
the error message in postgresql was:
ERROR 4: `HDF4_EOS:EOS_GRID:"MOD13A1.
A2012065.h35v10.005.2012082112322.hdf":MODIS_Grid_16DAY_500m_VI:500m 16
days EVI' does not exist in the file system,
and is not recognised as a supported dataset name.
The correct referencing in the vrt file is:
a) relativeToVRT has to be set to zero:
relativeToVRT="0"
b) the full path has to be inserted like this:
HDF4_EOS:EOS_GRID:"/some/path/toraster/MOD13A1.
days EVI'
I don't know itf the latter can be done with a gdal_translate switch, I
used sed for in-file replacement.
So up for some speed tests.. :-)
Greetings Chris
On Sun, Jul 20, 2014 at 8:41 PM, Christian Yrrman <yrrman at gmail.com> wrote:
> Hello David, hi all,
> thanks for the hint with SRID6842 for MODIS tiles and sorry for the late
> reply!
> In the meantime I have made several tests still trying to reference
> *vrt-files as out-of-database-references in postgis - with no luck. If I
> find something useful I'll post it to the group.
> Thanks and greetings! Chris
> On Mon, Jul 14, 2014 at 5:02 PM, David Haynes <haynesd2 at gmail.com> wrote:
>> Hello,
>> You might want to try this projection:
>> http://spatialreference.org/ref/sr-org/6842/postgis/
>> This the most accurate projections, despite the description on the
>> spatial reference site. I am doing related work and found this calculator
>> at the following url
>> http://landweb.nascom.nasa.gov/cgi-bin/developer/tilemap.cgi
>> There is no projection accuracy error when using SRID 6842.
>> On Fri, Jul 11, 2014 at 9:33 AM, Christian Yrrman <yrrman at gmail.com>
>> wrote:
>>> Hi All,
>>> I'm a newbie to this group, so hello everyone and thanks in advance for
>>> letting me participate :-)
>>> After several tests and searching on the net I'm a little stuck with the
>>> following problem:
>>> I have downloaded a bunch of MODIS tiles (MOD13A1) from [0] that I want
>>> to (only) reference in a postgis raster database. These tiles come in hdf
>>> containers with several layers in it
>>> - For a start, I'm only interested in the EVI layer, so I created EVI
>>> vrt files with command [1]
>>> - This gives me several EVI*.vrt files referencing EVI with the original
>>> sinusoidal projection. According to spatialreference.org, the closest
>>> SRS match is sr-org6974 [2].
>>> - As this is not in postgis, I've imported this into spatial_ref_sys [3]
>>> - Next, I'm using the following command to insert the data into raster
>>> table "modistest" with the following command:
>>> for i in `find / -name "EVI_origSRS*.vrt"`; do
>>> raster2pgsql -s 96974 -R -F -f rast -a $i modistest;
>>> done
>>> where:
>>> "-s 96974" - use the freshly imported MODIS SRS from [2]
>>> -R Register the raster as an out-of-db (filesystem) raster. Provided
>>> raster should have absolute path to the file
>>> -F Add a column with the filename of the raster.
>>> -f <column> Specify the name of the raster column
>>> -a Appends raster into current table, must be
>>> exactly the same table schema.
>>> I've built the index on rast in a separate step (not using switch -I)
>>> This populates table modistest (using | psql...), so it looks fine.
>>> However when I want to retrieve data from the raster, e.g. via
>>> SELECT ST_AsTiff(rast) from public.modistest where id=1158;
>>> I get an error message like this
>>> ERROR: rt_raster_from_gdal_dataset: Unable to get data from transformed
>>> raster
>>> CONTEXT: PL/pgSQL function "st_astiff" line 20 at RETURN
>>> and in the postgresql log I get
>>> ERROR 4:
>>> `HDF4_EOS:EOS_GRID:"MOD13A1.A2012065.h35v10.005.2012082112322.hdf":MODIS_Grid_16DAY_500m_VI:500m
>>> 16 days EVI' does not exist in the file system,
>>> So it looks like the layers were not correctly referenced - however I
>>> cannot see a mistake. I'm actually using "find / -name "EVI_origSRS*.vrt"
>>> to get the full path for the loop (not "for i in *vrt")
>>> Any help/advice is highly appreciated! In a next step, I would even like
>>> to transform the sinusoidal tile afterwards with ST_transform to epsg:4326.
>>> That would be fantastic, I'd have all tiles in original format in the file
>>> system and let postgis do all the rest.. :-)
>>> Thanks in advance and greetings!
>>> Chris
>>> [0] MODIS download website
>>> http://e4ftl01.cr.usgs.gov/MOLT/MOD13A1.005/
>>> [1] command to create vrt files:
>>> #!/bin/bash
>>> for i in *hdf; do
>>> echo Processing $i
>>> j=`gdalinfo $i| grep SUBDATASET_2_NAME | cut -d '=' -f 2`
>>> echo Extracted $j
>>> gdal_translate -of VRT "$j" EVI_origSRS_$i.vrt
>>> done
>>> [2] SRS projeciton for MODIS
>>> http://spatialreference.org/ref/sr-org/6974/
>>> [3] SQL command to insert MODIS SRS
>>> INSERT into spatial_ref_sys (srid, auth_name, auth_srid, proj4text, srtext)
>>> values ( 96974, 'sr-org', 6974, '+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs ',
>>> 'PROJCS["MODIS Sinusoidal",
>>> GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],
>>> AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
>>> UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]],
>>> PROJECTION["Sinusoidal"],
>>> PARAMETER["false_easting",0.0],
>>> PARAMETER["false_northing",0.0],
>>> PARAMETER["central_meridian",0.0],
>>> PARAMETER["semi_major",6371007.181],
>>> PARAMETER["semi_minor",6371007.181],
>>> UNIT["m",1.0],AUTHORITY["SR-ORG","6974"]]');
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140727/7aae4c7f/attachment.html>
