[postgis-users] PostGIS non functional on Ubuntu 14.04
Rémi Cura
remi.cura at gmail.com
Mon Jul 28 01:37:00 PDT 2014
Hm could you try the following command :
`sudo ldconfig`
It will refresh your dynamic link to library.
Cheers,
Rémi-C
2014-07-28 9:53 GMT+02:00 Luís de Sousa <luis.a.de.sousa at gmail.com>:
> Hi Clifford, thank you for replying. I found an old version of
> liblwgeom installed, but after removing it I am still getting the same
> error. If you know of other libraries that could be causing this let
> me know.
> Thank you,
> Luís
> On 25 July 2014 17:35, Clifford Snow <clifford at snowandsnow.us> wrote:
> > On Fri, Jul 25, 2014 at 1:03 AM, Luís de Sousa <
> > wrote:
> >> I have the following packages installed on Ubuntu 14.04 (all fetched
> >> with apt from the repositories):
> >> . postgresql-9.3
> >> . postgresql-9.3-postgis-2.1
> >> . libgeos-3.4.2
> >> When I try to add the PostGIS extension to a database I get following
> >> message:
> >> $ psql pg_testing -c "create extension postgis"
> >> ERROR: could not load library
> >> "/usr/lib/postgresql/9.3/lib/postgis-2.1.so":
> >> /usr/lib/liblwgeom-2.1.3.so: undefined symbol:
> >> GEOSDelaunayTriangulation
> >> I have posted full package details at GIS.SE:
> http://gis.stackexchange.com/questions/108308/postgis-non-functional-on-ubuntu-14-04
> >> Apparently, there is some mismatch between libgeos and postgis. But I
> >> have the exact same versions indicated in the compile guide at the
> >> Wiki:
> >> http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS21Ubuntu1310src
> >> Any advice on how to get PostGIS running is welcome. Thank you,
> > Not sure if this is the same problem, but when I upgraded to 14.04, along
> > with a new version of postgis/postgresql, postgis failed. The warning
> were
> > different. With help I discovered that I had conflicting libraries
> installed
> > that were causing the problem.
> > If you have older versions of postgis installed, make sure to remove all
> the
> > old libraries starting with liblwgeom.
> > Clifford
> > @osm_seattle
> > osm_seattle.snowandsnow.us
> > OpenStreetMap: Maps with a human touch
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140728/87e61cc8/attachment.html>
