[postgis-users] Building postgis on solaris 11
Phillip Ross
phillip.w.g.ross+postgis-users at gmail.com
Sun Mar 2 11:09:29 PST 2014
Hello...
I'm attempting to build postgis-2.1.1 on solaris 11.1 and was hoping to
find some assistance. I've built postgres(9.3.3 64bit), proj(4.8.0 64bit),
geos(3.4.2 64bit), json-c(0.11 64bit), and gdal(1.10.1 64bit), and I point
the postgis compilation to these dependencies. The configure script in
postgis runs fine, but the compilation trips up in a place that has me
confused.
The following is my configure line:
CFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64" ./configure \
--prefix=$HOME/postgis \
--with-geosconfig=$HOME/postgis/bin/geos-config \
--with-projdir=$HOME/postgis \
--with-gdalconfig=$HOME/postgis/bin/gdal-config \
--with-jsondir=$HOME/postgis
The following is the output of the configure script:
PostGIS is now configured for i386-pc-solaris2.11
-------------- Compiler Info -------------
C compiler: gcc -m64
C++ compiler: g++ -m64
SQL preprocessor:
-------------- Dependencies --------------
GEOS config: /export/home/pgsql/postgis/bin/geos-config
GEOS version: 3.4.2
GDAL config: /export/home/pgsql/postgis/bin/gdal-config
GDAL version: 1.10.1
PostgreSQL config: /export/home/pgsql/pgsql/bin/pg_config
PostgreSQL version: PostgreSQL 9.3.3
PROJ4 version: 48
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.7.6
JSON-C support: yes
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: disabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets: /usr/share/sgml/docbook/xsl-stylesheets
dblatex:
convert:
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
When I run the compilation with a simple "gmake" invocation... lots of
compilation happens, but after some time it stops with an error. The
following is the end of the output:
gcc -m64 -Wall -Wmissing-prototypes -Wpointer-arith
-Wdeclaration-after-statement -Wendif-labels -Wmissing-format-attribute
-Wformat-security -fno-strict-aliasing -fwrapv -fexcess-precision=standard
-fPIC -shared -o postgis-2.1.sopostgis_module.o lwgeom_accum.o
lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o
lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o
lwgeom_geos.o lwgeom_backend_api.o lwgeom_geos_prepared.o
lwgeom_geos_clean.o lwgeom_geos_relatematch.o lwgeom_export.o
lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geohash.o lwgeom_in_geojson.o
lwgeom_triggers.o lwgeom_dump.o lwgeom_dumppoints.o lwgeom_functions_lrs.o
long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o lwgeom_transform.o
gserialized_typmod.o gserialized_gist_2d.o gserialized_gist_nd.o
gserialized_estimate.o geography_inout.o geography_btree.o
geography_measurement.o geography_measurement_trees.o geometry_inout.o
-L/export/home/pgsql/pgsql-9.3.3/lib
-Wl,-R'/export/home/pgsql/pgsql-9.3.3/lib'
../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a
-L/export/home/pgsql/postgis/lib -L/export/home/pgsql/postgis/lib -lgeos_c
-lproj -L/export/home/pgsql/postgis/lib -ljson-c -lxml2
I../libpgcommon postgis.sql.in | grep -v '^#' | \
/usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.1'g" > postgis.sql
/bin/sh: line 1: I../libpgcommon: not found
/usr/bin/perl ../utils/create_undef.pl postgis.sql 93 >
uninstall_postgis.sql
cat postgis_drop_before.sql postgis.sql postgis_drop_after.sql >
postgis_upgrade_20_21.sql.in
/usr/bin/perl ../utils/postgis_proc_upgrade.pl postgis_upgrade_20_21.sql.in 2.0
Unable to locate target new version number in postgis_upgrade_20_21.sql.in
gmake[1]: *** [postgis_upgrade_20_21.sql] Error 255
gmake[1]: *** Deleting file `postgis_upgrade_20_21.sql'
gmake[1]: Leaving directory `/export/home/pgsql/src/postgis-2.1.1/postgis'
gmake: *** [all] Error 1
I'm not sure if the problem has something to do with libpqcommon or perl or
sql scripts. In looking at the postgis_proc_upgrade.pl script, it appears
to be looking for "INSTALL VERSION" string or something to populate the
to_version, but there is no instance of INSTALL VERSION in the sql script
that is being processed.
Anybody have any idea how I could further troubleshoot this?
Thanks!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140302/b9ded147/attachment.html>
