[postgis-users] Building postgis on solaris 11
Phillip Ross phillip.w.g.ross+postgis-users at gmail.com
Mon Mar 3 06:09:36 PST 2014
Thanks, but I figured out the problem after a little more digging.
The problem was that on solaris 11.1, /usr/bin/gcc is a symlink pointing to
/usr/gcc/4.5/bin/gcc and /usr/bin was in the PATH env var, but there is no
corresponding symlink for cpp.  After putting /usr/gcc/4.5/bin in the path,
the configure script was able to find cpp and set SQLPP appropriately.
Unfortunately the build fails further down with some linkling problems, but
I'll do a little more research on my own before following up on the mailing
list.
Thanks again for the help!  Much appreciated!
On Mon, Mar 3, 2014 at 5:12 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Sun, Mar 02, 2014 at 02:09:29PM -0500, Phillip Ross wrote:
> > I'm attempting to build postgis-2.1.1 on solaris 11.1 and was hoping to
> > find some assistance.  I've built postgres(9.3.3 64bit), proj(4.8.0
> 64bit),
> > geos(3.4.2 64bit), json-c(0.11 64bit), and gdal(1.10.1 64bit), and I
> point
> > the postgis compilation to these dependencies.  The configure script in
> > postgis runs fine, but the compilation trips up in a place that has me
> > confused.
> > The following is my configure line:
> > CFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64" ./configure \
> >     --prefix=$HOME/postgis \
> >     --with-geosconfig=$HOME/postgis/bin/geos-config \
> >     --with-projdir=$HOME/postgis \
> >     --with-gdalconfig=$HOME/postgis/bin/gdal-config \
> >     --with-jsondir=$HOME/postgis
> > The following is the output of the configure script:
> > PostGIS is now configured for i386-pc-solaris2.11
> >  -------------- Compiler Info -------------
> >   C compiler:           gcc -m64
> >   C++ compiler:         g++ -m64
> >   SQL preprocessor:
> > I../libpgcommon postgis.sql.in | grep -v '^#' | \
> > /usr/bin/perl -lpe "s'MODULE_PATHNAME'\$libdir/postgis-2.1'g" >
> postgis.sql
> > /bin/sh: line 1: I../libpgcommon: not found
> It looks like the configure script was unable to find a working
> SQL preprocessor.
> This is the snippet in configure.ac:
>   dnl SQL Preprocessor
>   dnl
>   AC_PATH_PROG([CPPBIN], [cpp], [])
>   if test "x$CPPBIN" != "x"; then
>     SQLPP="${CPPBIN} -traditional-cpp -P"
>   else
>     AC_PATH_PROG([GPP], [gpp_], [])
>     if test "x$GPP" != "x"; then
>       SQLPP="${GPP} -C -s \'" dnl Use better string support
>     else
>       SQLPP="${CPP} -traditional-cpp"
>     fi
>   fi
>   AC_SUBST([SQLPP])
> Feel free to file a ticket and send further debugging/patch there.
> --strk;
>  ()  ASCII ribbon campaign  --  Keep it simple !
>  /\  http://strk.keybit.net/rants/ascii_mails.txt
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140303/148e724c/attachment.html>
