[postgis-users] Postgis 2.1.1 compilation issue
Lydia López
lopezsanchez at gmail.com
Mon Mar 10 01:55:46 PDT 2014
Hi
I tried to compile postgis-2.1.1 in RedHat 6.3 with:
# ./configure --with-pgconfig=/usr/local/pgsql/bin/pg_config
--with-gdalconfig=/usr/local/bin/gdal-config
--with-geosconfig=/usr/local/bin/geos-config
--with-xml2config=/usr/bin/xml2-config --with-gui --with-raster
--with-topology
It gives:
PostGIS is now configured for x86_64-unknown-linux-gnu
-------------- Compiler Info -------------
C compiler: gcc -g -O2
C++ compiler: g++ -g -O2
SQL preprocessor: /usr/bin/cpp -w -traditional-cpp -P
-------------- Dependencies --------------
GEOS config: /usr/local/bin/geos-config
GEOS version: 3.4.2
GDAL config: /usr/local/bin/gdal-config
GDAL version: 1.10.1
PostgreSQL config: /usr/local/pgsql/bin/pg_config
PostgreSQL version: PostgreSQL 9.3.1
PROJ4 version: 48
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.6.26
JSON-C support: yes
PostGIS debug level: 0
Perl: /usr/bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
SFCGAL support: disabled
-------- Documentation Generation --------
xsltproc: /usr/bin/xsltproc
xsl style sheets:
dblatex:
convert: /usr/bin/convert
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
But, when I compile I get:
# make
usr/local/lib/libgdal.so -L/usr/local/pgsql/lib -L/usr/kerberos/lib64
-ljpeg -lpng -lpq -lpthread -lrt -lcurl -ldl -lgssapi_krb5 -lkrb5
-lk5crypto -lcom_err -lidn -lssl -lcrypto -lxml2 -lz
/usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so -lc -lm
../../liblwgeom/.libs/liblwgeom.so: undefined reference to `isfinite'
collect2: ld returned 1 exit status
make[2]: *** [raster2pgsql] Error 1
make[2]: se sale del directorio `/root/Descargas/postgis-2.1.1/raster/loader'
make[1]: *** [rtloader] Error 2
make[1]: se sale del directorio `/root/Descargas/postgis-2.1.1/raster'
make: *** [all] Error 1
¿Any idea? Thank you very much
