[postgis-users] Query performance really slow..
Pietro Rossin
pierigis at gmail.com
Thu Mar 13 07:18:45 PDT 2014
"GroupAggregate (cost=324001.58..329989.92 rows=21516 width=28454)"
" -> Sort (cost=324001.58..324055.53 rows=21582 width=28454)"
" Sort Key: bacini.codice_bac, bacini.nome, bacini.codice_cor,
particellepac2006.descrizione"
" -> Nested Loop (cost=59426.24..59835.94 rows=21582 width=28454)"
" -> Seq Scan on bacini_elementari bacini (cost=0.00..138.27
rows=327 width=28397)"
" -> Materialize (cost=59426.24..59428.06 rows=66 width=57)"
" -> HashAggregate (cost=59426.24..59427.07 rows=66
width=1169)"
" -> Seq Scan on particellepac2006
(cost=0.00..56355.83 rows=614083 width=1169)"
Thanks!
2014-03-13 15:15 GMT+01:00 Marcelo Soares Souza [via PostGIS] <
ml-node+s17n5005873h87 at n6.nabble.com>:
> Use EXPLAIN to show the execution plan of a statement, and post here.
> EXPLAIN SELECT sum(st_area(ST_Intersection(bacini.geom,colture.geom)))
> as areacoltura, codice_bac, nome, codice_cor, colture.descrizione FROM
> drologia.bacini_elementari as bacini, (SELECT st_collect(geom) as geom,
> descrizione FROM varie.particellepac2006 group by 2) as colture group by
> 2,3,4,5;
> March 13 2014 11:00 AM, "Pietro Rossin" wrote:
> > Hi all
> > I'm trying to query 2 vector layers;
> > b) bacini_elementari that is river basins - 327 elements
> > b) particellepac2006 colture parcels - 614000 elements
> > I want to intersect these two layers and get the sum of the area of each
> > kind of colture for each river basin.
> > To reduce the number of colture vectorial features I made a collect
> query
> > (grouping by kind of colture) and I made a intersection between this
> > geometry aggregation and all 327 basins.
> > My query is:
> > SELECT sum(st_area(ST_Intersection(bacini.geom,colture.geom))) as
> > FROM idrologia.bacini_elementari as bacini,
> > (SELECT st_collect(geom) as geom, descrizione
> > group by 2,3,4,5
> > it's 5000000ms that the query is running and I don't have any result
> yet...
> > The two geometry column have an index (but I think it's not used in this
> > query)
> > Mi pc id dual opteron with 4Gb RAM,
> > "PostgreSQL 9.1.3, compiled by Visual C++ build 1500, 32-bit"
> > "POSTGIS="2.0.0 r9605" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March
> > 2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
> > LIBJSON="UNKNOWN" TOPOLOGY RASTER"
> > View this message in context:
> http://postgis.17.x6.nabble.com/Query-performance-really-slow-tp5005872.html
> > Sent from the PostGIS - User mailing list archive at Nabble.com.
> > postgis-users mailing list
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=5005873&i=0>
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5005873&i=1>
> If you reply to this email, your message will be added to the discussion
> below:
> http://postgis.17.x6.nabble.com/Query-performance-really-slow-tp5005872p5005873.html
> To unsubscribe from Query performance really slow.., click here<http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5005872&code=cGllcmlnaXNAZ21haWwuY29tfDUwMDU4NzJ8MjMwODY1MTQ5>
> NAML<http://postgis.17.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://postgis.17.x6.nabble.com/Query-performance-really-slow-tp5005872p5005874.html
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140313/6b28deb0/attachment.html>
