[postgis-users] Performance comparison between PostGIS's topology creation and topojson (the module)
Rémi Cura
remi.cura at gmail.com
Tue Mar 18 02:19:44 PDT 2014
Hey,
Sandro could you give more details about how postgis topology use
PolygonizeGraph in GEOS?
In particular, is there a geos graph corresponding to a topology or is it
rebuild every time we need to make a change to this graph? (is only a small
part rebuild or the whole graph?)
If it is stored, is it in cache or serialized and put in db?
And how does it work when inserting/deleting/changing a line into the
topology model regarding this geos topological graph?
Thanks,
Rémi-C
2014-03-18 8:36 GMT+01:00 Sandro Santilli <strk at keybit.net>:
> On Tue, Mar 18, 2014 at 11:04:27AM +1100, Luca Morandini wrote:
> > On 18/03/14 10:28, Stephen V. Mather wrote:
> > >I don't know. Javascript is pretty fast these days. Given this and 1)
> no
> > >database overhead, 2) Not the same level of completeness to the
> algorithm, I
> > >would not be surprised by the JS being faster, in fact I'd expect it.
> > Certainly transactions are an overhead, but closeness to the data
> > should be an advantage (though not that large for small datasets).
> You fetch all the data into memory before turning into TopoJSON,
> so the data is immediately available also to javascript.
> > Actually, I presume adding one geometry at a time may be the real
> > performance killer, compared with knowing in advance all the
> > geometries that make the topology.
> That's the other aspect of it, but as I said the PostGIS equivalent
> of that (CreateTopogeo) is currently also not optimized to take
> advantage of that. I'd love to see some contribution in the direction
> of speeding that up :)
> --strk;
> () ASCII ribbon campaign -- Keep it simple !
> /\ http://strk.keybit.net/rants/ascii_mails.txt
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140318/288df1f4/attachment-0001.html>
