[postgis-users] Urgent help needed, messed up my postgis 2.1 server by installing latest QGIS pacake
Morten Sickel
morten at sickel.net
Tue Mar 18 13:22:52 PDT 2014
If you installed postgres using apt-get, the data files should be in
/var/lib/postgres/9.3/data postgres is usually quite good at not messing
up data during upgrades, but just in case, I would make a quick backup. if
you do a sudo du -s /var/lib/postgres/9.3/data/base/* you should see at
least three directories - one of them contains your entire database, if it
is less than three there or none of them has a reasonable size, you may be
in trouble... (unless you have set up postgres to store data somewhere
else) If you have installed postgres through make /make install, the
databases may be stored somewhere else.
Morten
Willem Buitendyk skrev:
> The wifi on the plane is a lot erratic. How could I check if I still have
> the data? I'll certainly perform a backup as you suggest. I don't have a
> separate virtual machine unfortunately. I have far too many other systems
> associated to the current server, ip address, etc
> On Tue, Mar 18, 2014 at 1:03 PM, Morten Sickel <morten at sickel.net> wrote:
>> Did you accidentally upgrade postgis or postgres to a new minor version?
>> An apt-get autoremove (after having done a apt-get remove qgis) will
>> only
>> remove dependencies that qgis have pulled in, I do not think it will
>> rollback anything to an older version - so I don't think that will help,
>> although it should not do any harm either.
>> As long as the database files still do exist, it should be possible to
>> get
>> back to a working system using a few apt-gets and/or dpkg commands. So
>> just in case, shut down the postgres server and do a backup of
>> /var/lib/postgresql/9.3/data (or if you have put the database files
>> somewhere else you shoud know where they are) (use tar or some other
>> utility that gets the file ownerships and permissions right)
>> Do you have access to any other virtual or real machine? then you can
>> install postgres / postgis on that, stop postgres and just copy over the
>> database files.
>> Morten
>> > Hi all,
>> > I'm currently sitting on a plane having made a huge mistake yesterday.
>> I
>> > have a server that runs constantly, supplying data to clients on a
>> daily
>> > basis. The server is Ubuntu 12.04 and I had successfully installed
>> and
>> > have been running PostGIS 2.1 and Postgresql 9.3 for the last 3
>> months.
>> > Prior to leaving for my vacation I thought it would be great to
>> install
>> > QGIS so I could remotely view my database. The problem is the QGIS
>> > install
>> > altered my postgis and libgdal1 dependencies.
>> > Here are the commands I issued that got me into this mess:
>> > sudo apt-get update
>> > sudo apt-get install qgis pythin-qgis
>> > sudo apt-get install qgis python-qgis
>> > sudo apt-get install python-qgis
>> > gpg --keyserver keyserver.ubuntu.com --recv 47765B75
>> > gpg --export --armor 47765B75 | sudo apt-key add -
>> > sudo apt-get update
>> > sudo apt-get install python-software-properties
>> > sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>> > sudo apt-get update
>> > sudo apt-get install qgis python-qgis qgis-plugin-grass
>> > sudo apt-get install libssl0.9.8
>> > I am uncertain how to proceeed because I remember something similar
>> > happening years ago (irony of ironies) and it ended up corrupting my
>> > Ubuntu
>> > server when I tried to repair.
>> > I'm looking for some sage advise to correct this a painless as
>> possible.
>> > Is it safe to perform an apt-get autoremove?
>> > Please help an overstressed dad enjoy his vacation trip to Disney with
>> his
>> > wife and kids. I promise I won't go installing packages all willy
>> nilly
>> > in
>> > the future.
>> > Thanks
>> > Willem
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at lists.osgeo.org
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
