[postgis-users] soft upgrade 2.0.3 > 2.1.1
Jason
jmathis at redzonesoftware.com
Wed Mar 19 09:24:51 PDT 2014
aahh gotcha. Continue on my friend thanks for the assist.
-jason
On Tuesday, March 18, 2014 3:52:00 PM UTC-6, Jason wrote:
> Hi All,
> OS: centos 6.5
> Postgres: 9.2.7
> PostGIS: 2.0.3
> We have recently finished cleaning up and consolidating apps/servers and
> upgraded to postgres 9.2.7. Now that postgres is upgraded we decided to get
> postgis upgraded as well; currently we are at 2.0.3. According to postgis
> docs we can do the "soft upgrade" path, which sounds wonderful. We used
> "create extension" for all our 2.0.3 databases.We are on centos 6.5 and I
> am using yum to update the postgis packages. I did a quick test on a vm
> that had a empty database and the postgis update went fine. After a little
> research I figured it was time to run the process on our dev node. The
> steps are:
> yum install postgis2_92 #2.1.1
> psql -c "ALTER EXTENSION postgis UPDATE TO '2.1.1';"
> The yum installed went fine but the "alter extension" failed with:
> ERROR: cannot drop function st_union(geometry) because other objects
> depend on it
> It went on to list a few views that used that function. I tried dropping
> those views but it just moved on to other views that had postgis functions
> in them. Dropping all views is not worth it:)
> Does anyone know if soft upgrading from 2.0.3 > 2.1.1 is possible? Could
> it be something in our setup that is stopping us from upgrading. Otherwise
> it looks like a hard upgrade is in our future, and its hard to get excited
> about that.
> Thanks!
> This transmission contains confidential and privileged information
> intended solely for the party identified above. If you receive this message
> in error, you must not use it or convey it to others. Please destroy it
> immediately and contact the sender at (303) 386-3955 or by return e-mail to
> the sender.
This transmission contains confidential and privileged information intended
solely for the party identified above. If you receive this message in
the sender.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140319/ddf868a6/attachment-0001.html>
