[postgis-users] Controlling PostGIS memory usage
Dan Gast
dan at stormpulse.com
Wed Mar 26 14:29:04 PDT 2014
Yeah, that works and is much faster than ST_Distance().
For what it's worth, if I:
ALTER TABLE store ADD COLUMN buf Geography(Polygon);
UPDATE store SET buf = ST_Buffer(geog, 400000);
SELECT COUNT(*) FROM person AS p, store AS s WHERE ST_Intersects(s.buf, p.geog);
it works and it's fast... as fast as or slightly faster than ST_DWithin().
If general consensus is that it shouldn't be doing that, I will file a
bug. I just wanted to be sure I'm not hitting a known and documented
issue.
Thanks,
Dan
On Wed, Mar 26, 2014 at 3:16 PM, George Silva <georger.silva at gmail.com> wrote:
> Have you tried using ST_DWithin?
