[postgis-users] more memory issues with raster2pgsql
Bborie Park dustymugs at gmail.com
Sat Mar 29 07:29:19 PDT 2014
I think you can just connect to the database with psql and issue the
following:
postgres=# SHOW client_encoding;
It should return something like...
 client_encoding
 UTF8
(1 row)
If your database doesn't return UTF8, you can forcefully set client_encoding
ALTER DATABASE mydb
  SET client_encoding = UTF8
-bborie
On Fri, Mar 28, 2014 at 10:43 PM, georgew <gws293 at hotmail.com> wrote:
> Thanks bborie, this is what I did, but no improvement:
> Microsoft Windows [Version 6.3.9600]
> (c) 2013 Microsoft Corporation. All rights reserved.
> C:\WINDOWS\system32>set PGCLIENTENCODING=UTF8
> C:\WINDOWS\system32>psql -U postgres -d NZTPU -f c:\cb09.sql
> BEGIN
> psql:c:/cb09.sql:2: NOTICE:  table "cb09_3" does not exist, skipping
> DROP TABLE
> CREATE TABLE
> psql:c:/cb09.sql:4: ERROR:  could not load library "C:/Program
> Files/PostgreSQL/
> 9.3/lib/rtpostgis-2.1.dll": unknown error 998
> LINE 1: INSERT INTO "cb09_3" ("rast","filename") VALUES ('0100000100...
> psql:c:/cb09.sql:5: ERROR:  current transaction is aborted, commands
> ignored
> unt
> il end of transaction block
> psql:c:/cb09.sql:6: ERROR:  current transaction is aborted, commands
> ignored
> unt
> psql:c:/cb09.sql:7: ERROR:  current transaction is aborted, commands
> ignored
> unt
> ROLLBACK
> psql:c:/cb09.sql:9: ERROR:  relation "cb09_3" does not exist
> I tried again and the second time got the out of memory error.
> What can I try next? I have searched everywhere but have not found a
> suitable answer.
> But as a start how can I determine what the default character set encoding
> is for the server and for the client?
> http://postgis.17.x6.nabble.com/more-memory-issues-with-raster2pgsql-tp5006000p5006008.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140329/35e56363/attachment.html>
