[postgis-users] pgsql2shp : failing to output 3D
Sandro Santilli
strk at keybit.net
Mon Mar 31 08:37:33 PDT 2014
On Mon, Mar 31, 2014 at 05:25:44PM +0200, Rémi Cura wrote:
> it outputs 2.
> creation of the table is more than explicit :
> DROP TABLE IF EXISTS registration_joined_with_trajectory;
> CREATE TABLE registration_joined_with_trajectory (
> ,geom geometry(LinestringZ,931008)
> ,geom_surf geometry(PolygonZ,931008)
> What do you think?
And what does pgsql2shp print in the header ?
Like:
Initializing...
Done (postgis major version: 2).
Output shape: PolyLineZ
Also, first line of output from pgsql2shp invoked
with no arguments ?
--strk;
> 2014-03-31 17:14 GMT+02:00 Sandro Santilli <strk at keybit.net>:
> > On Mon, Mar 31, 2014 at 05:06:57PM +0200, Rémi Cura wrote:
> > > Hey,
> > > my pgsql2shp doesn't output 3D (but 2D).
> > > Am I missing something ?
> > > /usr/lib/postgresql/9.3/bin/pgsql2shp -f registration_surf_3D -h
> > localhost
> > > -p 5433 -u postgres -P uGuess -g geom_surf -r import_xml
> > > public.registration_joined_with_trajectory
> > > I have the latest postgis/geos/postgres/gdal.
> > > Of course ST_AsText output 3D geometry,
> > > the table is defined as geometry(polygonZ, XXXX)
> > What does this give you ?
> > SELECT max(ST_zmflag("geom_surf"::geometry))
> > FROM public.registration_joined_with_trajectory;
> > --strk;
> > postgis-users mailing list
> > postgis-users at lists.osgeo.org
> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
() ASCII ribbon campaign -- Keep it simple !
/\ http://strk.keybit.net/rants/ascii_mails.txt
