[postgis-users] Point inside a polygon
J.Alejandro Martinez Linares
islanis at infomed.sld.cu
Thu May 1 21:32:40 PDT 2014
Hi people, i need your help, i was using st_centroid to get a point that
be inside a polygon butr st_centroid got a property that is a problem
to me, it returns a point that not always is inside the polygon, cause
when the polygon has an irregular form, the point that st_centroid is
outside the polygon, and i need a function that do a similar thing that
st_centroid but i need that the point it returns always be inside the
polygon, is there a function that do that?
cheers.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
