[postgis-users] Point inside a polygon
Åsmund Tokheim asmundto at gmail.com
Fri May 2 12:38:31 PDT 2014
Hi
You can use st_closestpoint(geom, st_centroid(geom)) to make sure that the
returned point is in most circumstances at or near the centroid, and always
at least on the boundary of the polygon. While st_pointonsurface certainly
will be faster, it will often choose a more random point on the surface.
Åsmund
On Fri, May 2, 2014 at 12:45 PM, Nicolas Ribot <nicolas.ribot at gmail.com>wrote:
> Hi,
> Use st_pointOnSurface (
> http://postgis.net/docs/manual-2.1/ST_PointOnSurface.html)
> Nicolas
> On 2 May 2014 06:32, J.Alejandro Martinez Linares <islanis at infomed.sld.cu>wrote:
>> Hi people, i need your help, i was using st_centroid to get a point that
>> be inside a polygon butr st_centroid got a property  that is a problem to
>> me, it returns a point that not always is inside the polygon, cause when
>> the polygon has an irregular form, the point that st_centroid is outside
>> the polygon, and i need a function that do a similar thing that st_centroid
>> but i need that the point it returns always be inside the polygon, is there
>> a function that do that?
>> cheers.
>> Este mensaje le ha llegado mediante el servicio de correo electronico que
>> ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema
>> Nacional de Salud. La persona que envia este correo asume el compromiso de
>> usar el servicio a tales fines y cumplir con las regulaciones establecidas
>> Infomed: http://www.sld.cu/
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140502/c94c5487/attachment.html>
