[postgis-users] Geometry vs Linestring
Rémi Cura
remi.cura at gmail.com
Wed May 7 08:36:42 PDT 2014
You can also cnahge the type of the column of the table afterward to be
more precise than geometry(0).
(see ALTER TABLE ...)
Cheers,
Rémi-C
2014-05-07 16:11 GMT+02:00 Nicolas Ribot <nicolas.ribot at gmail.com>:
> Hi,
> You could also cast the call to st_makeline into a specific geometry type,
> with some SRID (or 0 if data has no SRID) :
> ... ST_MakeLine(seeds.geom)::geometry(Linestring, <srid>)
> Nicolas
> On 7 May 2014 15:56, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>> Linestrings are geometry objects. If you want your table to have tighter
>> constraints on it create the table first and use addgeometrycolumn() to set
>> the geometry type and constraints then use
>> insert into "l_506" (oid, geom) from SELECT ...
>> CREATE TABLE AS does not know what the query will return as far as
>> geometry types so it make a general "geometry" column.
>> -Steve
>> On 5/7/2014 9:38 AM, Pier Lorenzo Marasco wrote:
>>> Hi all,
>>> I'm trying to make something very easy but I've a problem with results.
>>> I've two tables and I need to make lines from the joins of these two.
>>> I've try with this :
>>> CREATE TABLE "l_506" AS
>>> SELECT elements.oid, ST_MakeLine(seeds.geom) AS geom
>>> FROM elements
>>> JOIN seeds ON (elements.oid=seeds.oid)
>>> WHERE elements.code='0506'
>>> GROUP BY elements.oid;
>>> All the elements in seeds are linestring but what I achieve is a
>>> geometry table. Ok.. I should alter the column type and everything goes
>>> as I aspect but I would like to understand where I'm getting wrong.
>>> L.
>>> postgis-users mailing list
>>> postgis-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140507/e6ed2e9e/attachment.html>
