[postgis-users] mulitpolygon with type set to geometry(Geometry, 4326)
Jason Mathis
jmathis at redzonesoftware.com
Thu May 8 13:49:27 PDT 2014
Hello,
I am fairly new to postgis so it would be great if someone could point me in the right direction on how to fix this issue. Or if its even fixable.
I have a table that stores polygons and multi polygons with a column:
report_geom geometry(Geometry,4326)
I have a view that uses that column like:
st_centroid(report_geom) as pt_geom
The issue is when you use the st_centroid is removes the srid and leaves it a plain geometry. Which can make it a bit inconvenient for use in arc and qgis apps. Is there a way to cast it to be a point with 4326?
Thanks all!
-jason
This transmission contains confidential and privileged information intended
solely for the party identified above. If you receive this message in
error, you must not use it or convey it to others. Please destroy it
immediately and contact the sender at (303) 386-3955 or by return e-mail to
the sender.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140508/769acde8/attachment.html>
