[postgis-users] Dted elevations
Gold, Jack L (US SSA)
jack.gold at baesystems.com
Fri May 9 20:06:52 PDT 2014
Spatial index is in place. A rebuild of the database seems to have solved the problem, but I still don't know what caused sudden slow-down. If I had a corrupted raster table, would that cause this type of response? Thanks for the help. Turns out I had a similar problem at least a year ago and Bborie helped out, but I reviewed those adjustments and everything seems to be in place. I'm looking at a combination of level 0, level 1 and level 2 dteds all loaded in the same raster table as well. I'm wondering if that is generating some havoc on the lookup.
--Jack
-----Original Message-----
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Pierre Racine
Sent: Friday, May 09, 2014 1:26 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Dted elevations
What happened when you remove "and st_value (dted_elevations.rast, f.geom) is not null"? You get null values?
Do you have many nodata values in your raster?
How is your raster tiled? Did you build a spatial index on the raster tiles?
Pierre
> bounces at lists.osgeo.org] On Behalf Of Gold, Jack L (US SSA)
> Sent: Friday, May 09, 2014 1:01 PM
> To: 'postgis-users at lists.osgeo.org'
> Subject: [postgis-users] Dted elevations
> I know this question has already been answered a hundred times but I
> am at a remote location currently with only email access right now and
> I hope someone can help. The following query is taking close to a
> second to run and I think it should be much faster.
> Select st_value from (with f as ( select st_transform ( st_SetSRID(
> st_MakePoint('106','32'), 4326) as geom) select
> st_value(dted_elevations.rast, f.geom) from dted_elevations cross join
> f where st_intersects ( dted_elevations.rast , f.from) and st_value
> (dted_elevations.rast, f.geom) is not null) as st_value;
> Any help is greatly appreciated.
> Jack Gold
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
