[postgis-users] ST_MakeLine() woes
georgew gws293 at hotmail.com
Sun May 11 18:01:33 PDT 2014
Thank you Remi, I assume that means that my original code was correct
(although it produces unwanted results).
I am slowly reaching the conclusion that the problem is with
st_intersection(), which traverses the raster in an order which is not
compatible with my line shape and any attempt to create order by using a
sequence number will only cement the wrong order. If my assumption is
correct, maybe there is no solution to this problem.
But I am not a GIS person, so I'll defer to those who know what they are
talking about.
View this message in context: http://postgis.17.x6.nabble.com/ST-MakeLine-woes-tp5006266p5006274.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
