[postgis-users] ST_MakeLine() woes
georgew
gws293 at hotmail.com
Mon May 12 16:08:30 PDT 2014
thanks Remi, attached is the result after running your code, no change
unfortunately.
I had to make some slight changes to the code to make it work. The image has
the code.
However you also say that my approach is not as robust as it could be. Any
suggestions on how to make it more robust?
newline.png <http://postgis.17.x6.nabble.com/file/n5006277/newline.png>
View this message in context: http://postgis.17.x6.nabble.com/ST-MakeLine-woes-tp5006266p5006277.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
