[postgis-users] getting raster values for point from st_value
Jason Mathis jmathis at redzonesoftware.com
Wed May 14 08:46:53 PDT 2014
Well I was visualizing the tiff file not the postgis raster table. Its seems somewhere along the lines the qgis raster plugin dropped off. Although I am able to see the raster tables in the db manager and can drag/drop the table, horribly slow but works.
The raster extents or just the raster table do not overlay with the point, which explains the problem. I still don’t understand what I did wrong. Attaching a screen shot.
thanks,
On May 14, 2014 at 7:01:27 AM, Pierre Racine (pierre.racine at sbf.ulaval.ca) wrote:
You said you could visualize this table in QGIS? Or were you speaking about a shapefile? You can visualize the rastextets table and the points table the same way.
Pierre
> -----Original Message-----
> From: Jason Mathis [mailto:jmathis at redzonesoftware.com]
> Sent: Tuesday, May 13, 2014 6:30 PM
> To: PostGIS Users Discussion; Pierre Racine
> Subject: Re: [postgis-users] getting raster values for point from st_value
> Hi Pierre,
> Thanks so much for super quick response. You will have to forgive me I am
> fairly new to postgis.
> Creating the table is no problem but how would I check if it overlaps with
> my points?
> thanks!
> On May 13, 2014 at 4:08:40 PM, Pierre Racine (pierre.racine at sbf.ulaval.ca)
> wrote:
> Create a new table with the extents of the raster tiles and check if it
> overlaps with your points:
> CREATE TABLE rastextets AS
> SELECT rast::geometry
> FROM tbl_raster
> Pierre
> > From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-
> users-
> > bounces at lists.osgeo.org] On Behalf Of Jason Mathis
> > Sent: Tuesday, May 13, 2014 5:56 PM
> > To: postgis-users at lists.osgeo.org
> > Subject: [postgis-users] getting raster values for point from
> st_value
> > Hi all,
> > I have recently loaded a good amount of rasterized shape files into
> a db. I
> > mainly used gdal_rasterize and raster2pgsql. The shape files were
> in NAD83
> > so I used the below commands to rasterized and load.
> > gdal_rasterize -at -a desc -where "desc='Very High'" -burn 2 -tr 30
> 30 -ot
> > byte -a_nodata -99 shape_file.shp raster.tiff
> > raster2pgsql -d -s 5070 -t 100x100 -F -I -C -Y raster.tiff tbl_raster |
> psql -d
> > raster_db
> > I had two sets of shape files one set had about 10 burn values and
> another
> > had about 50. The issue is getting these values out of the raster. I
> believe I
> > should be using something from this page:
> > http://postgis.net/docs/RT_ST_Value.html.
> > I can visualize this file in QGIS and it looks good, the histogram
> shows
> > values. I can also use the postgis functions, st_summarystats or
> > st_histogram to see some data but I need to be able to query a
> given point
> > and return the raster value.
> > I have this:
> > SELECT ST_Value(rast,(ST_Point( -111.750185, 34.886948)))
> > FROM tbl_raster
> > WHERE st_intersects(rast, (ST_Point(-111.750185, 34.886948)))
> > Then i thought oh wait should I set the srid?:
> > SELECT ST_Value(rast,(ST_SetSRID(ST_Point( -111.750185,
> > 34.886948),5070)))
> > FROM tbl_raster
> > WHERE st_intersects(rast, (ST_SetSRID(ST_Point(-111.750185,
> > 34.886948),5070)))
> > Still I get nothing, then I thought I need to transform so I got this:
> > SELECT ST_Value(rast,(ST_Transform(ST_SetSRID(ST_Point( -
> 111.762866,
> > 34.874309),5070),4326)))
> > FROM tbl_raster
> > WHERE st_intersects(rast, (ST_Transform(ST_SetSRID(ST_Point( -
> > 111.762866, 34.874309),5070),4326)))
> > But in the end nothing.
> > I did need to add the SRID to the spatial_ref_sys table:
> > INSERT into spatial_ref_sys (srid, auth_name, auth_srid,
> proj4text, srtext)
> > values ( 5070, 'EPSG', 5070, '+proj=aea +lat_1=29.5 +lat_2=45.5
> +lat_0=23
> > +lon_0=-96 +x_0=0 +y_0=0 +ellps=GRS80
> +towgs84=0,0,0,0,0,0,0
> > +units=m +no_defs ', 'PROJCS["NAD83 / Conus
> Albers",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHER
> > OID["GRS
> 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,
> 0,0,0,0,0,0],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0,AUTHORIT
> Y["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG
> ","9122"]],AUTHORITY["EPSG","4269"]],PROJECTION["Albers_Conic_Equal_
> Area"],PARAMETER["standard_parallel_1",29.5],PARAMETER["standard_par
> allel_2",45.5],PARAMETER["latitude_of_center",23],PARAMETER["longitude
> > _of_center",-
> 96],PARAMETER["false_easting",0],PARAMETER["false_northing",0],UNIT["
> metre",1,AUTHORITY["EPSG","9001"]],AXIS["X",EAST],AXIS["Y",NORTH],AUT
> > HORITY["EPSG","5070"]]’);
> > But ultimately I have nothing I can’t seem to get any data out
> using a query
> > with a point value. I am thinking it has to do with the srid? Since I
> can
> > visually inspect it and see data.
> > Anyone have any hot ideas as to why I am not seeing data?
> > Thanks!
> > This transmission contains confidential and privileged information
> intended
> > solely for the party identified above. If you receive this message in
> error,
> > you must not use it or convey it to others. Please destroy it
> immediately
> > and contact the sender at (303) 386-3955 or by return e-mail to
> the sender.
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> This transmission contains confidential and privileged information intended
> solely for the party identified above. If you receive this message in error,
> you must not use it or convey it to others. Please destroy it immediately
> and contact the sender at (303) 386-3955 or by return e-mail to the sender.
error, you must not use it or convey it to others. Please destroy it
immediately and contact the sender at (303) 386-3955 or by return e-mail to
the sender.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140514/1e51d623/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140514/1e51d623/attachment.obj>
