[postgis-users] Postgis raster with postgis 1.5.3.2 on Debian 7.5?
Mike Toews mwtoews at gmail.com
Wed May 14 16:24:21 PDT 2014
You will need to use PostGIS 2.x (currently 2.1). If you have one or
more existing databases that use PostGIS, then before upgrading, be
sure to see the "hard upgrade" instructions to dump your database(s):
http://postgis.net/docs/postgis_installation.html#hard_upgrade
After dumping your v1.5 database(s), you can upgrade to a more recent
version of PostGIS. There are several options, such as compiling from
source. The easiest is to use the PGDG Apt repository, with
instructions at http://wiki.postgresql.org/wiki/Apt
After installing the v2.x version of PostGIS, then complete the
remaining steps in the hard upgrade procedure.
-Mike
On 14 May 2014 01:00, dandrigo <lcelati at latitude-geosystems.com> wrote:
> Dear all,
> Currently, on my debian server i have postgresql 9.1 and postgis 1.5.3.2,
> I have to work with postgis raster.
> 1/ Is there a way in order to install postgis raster with my current postgis
> 1.5.3.2
> 2/ If it's  not the case, i am obliged to install postgis 2.0? If yes, could
> you tell me the easiest way to install postgis 2.0 on my debian server
> please?
> In advance, thank you for your reply.
> Regards.
