[postgis-users] Uploading data to a different server via command prompt
Rémi Cura
remi.cura at gmail.com
Thu May 15 00:21:43 PDT 2014
Hey,
to test stuff, shp2pgsql-gui may be faster.
Cheers,
Rémi-C
2014-05-14 18:20 GMT+02:00 Shane StClair <shane at axiomalaska.com>:
> Hi Mark,
> shp2pgsql just generates SQL statements to create the shapefile data. psql
> actually executes those statements, so that's where you want to specify
> connection parameters for the other server.
> http://www.postgresql.org/docs/9.2/static/app-psql.html
> So something like:
> for %%f in (*.shp) do shp2pgsql -d -I -s 103749 -W LATIN1 %%f %%~nf |
> psql -w -h 192.168.1.50 -U postgres -d lyongis
> You can put your authentication credentials into a .pgpass file to avoid
> retyping the password for each shapefile.
> http://www.postgresql.org/docs/9.3/static/libpq-pgpass.html
> Also note that your remote server will need to be configured to allow
> external connections and password authentication for the postgres user.
> Best,
> Shane
> On Wed, May 14, 2014 at 8:50 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>> Hello,
>> I understand that I can use shp2pgsql to load shapefiles on the
>> localhost. I would like to know load data onto another server, and I would
>> like to verify that I am doing everything correct. Specifically:
>> 1) How I can adjust this code so that I can update the gis data on a
>> different server?
>> 2) How will I specify the password on a different machine?
>> 3) Do I need to do anything in addition to this to create spatial
>> indexes?
>> Current code that I am using to load a directory of shapefiles.
>> set PATH=C:\Program Files\PostgreSQL\9.2\bin;%PATH%
>> psql -w -U postgres -d lyongis
>> Thanks
>> Sincerely,
>> Mark Volz, GISP
>> Lyon County GIS Coordinator
>> postgis-users mailing list
>> postgis-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> Shane StClair
> Software Engineer
> Axiom Consulting & Design
> http://www.axiomalaska.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140515/4dc0437b/attachment.html>
