[postgis-users] problem with st_makevalid and (LineString)
Ivan Santiago
isantiago at ogp.pr.gov
Fri May 16 08:35:51 PDT 2014
Hello:
Run
SELECT PostGIS_full_version();
TO know if your installation has GEOS 3.3.0 or above.
Iván Santiago
GIS Specialist
Information Technologies
Office of Management and Budget
787.725.9420 x 2378
Calle Cruz 254
PO Box 9023228
San Juan, PR 00902-3228
http://gis.pr.gov
-----Original Message-----
From: postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of islanis at infomed.sld.cu
Sent: Friday, May 16, 2014 11:24 AM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] problem with st_makevalid and (LineString)
Hello people, i got a problem where i have no idea what can i do.
I have this table
CREATE TABLE ft_potencial
id_dw_ft_potencial integer NOT NULL,
id_dw_tipo integer NOT NULL,
id_dw_mes integer NOT NULL,
id_dw_municipio integer NOT NULL,
id_dw_date integer NOT NULL,
potencial real NOT NULL,
area real NOT NULL,
the_geom geometry(Polygon,4326),
CONSTRAINT ft_potencial_pkey PRIMARY KEY (id_dw_ft_potencial, id_dw_tipo, id_dw_mes, id_dw_municipio, id_dw_date)
WITH (
OIDS=FALSE
and i want to clean the errors that it has using the function ST_MakeValid in this way
update ft_potencial set the_geom=ST_MakeValid(the_geom);
but it always return this error
ERROR: Geometry type (LineString) does not match column type (Polygon)
********** Error **********
ERROR: Geometry type (LineString) does not match column type (Polygon) Estado SQL:22023
what can i do to fix or clean the geometry without problems.
please help.
thanks
This message was sent using IMP, the Internet Messaging Program.
Este mensaje le ha llegado mediante el servicio de correo electronico que ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema Nacional de Salud. La persona que envia este correo asume el compromiso de usar el servicio a tales fines y cumplir con las regulaciones establecidas
Infomed: http://www.sld.cu/
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
