[postgis-users] problem with st_makevalid and (LineString)
Rémi Cura remi.cura at gmail.com
Fri May 16 12:30:16 PDT 2014
You can try to analyze a bit to understand better
(for the following I consider your table doesn't contains too much data)
with the_data AS (
SELECT the_geom, ST_ISValid(the_geom) AS is_valid,
ST_IsValidReason(the_geom)
FROM ft_potencial
SELECT *, ST_AsText(ST_MakeValid(the_geom)) AS corrected_geom,
ST_AsText(the_geom) AS original_geometry, detail.*
FROM the_data, *ST_IsValidDetail*(the_geom) AS detail
WHERE is_valid = false
AND GeometryType(the_geom) ILIKE '%POLYGON%'
 My guess : you have an invalid no-area polygon, so the makevalid function
transform it into a line
Cheers,
Rémi-C
2014-05-16 18:14 GMT+02:00 <islanis at infomed.sld.cu>:
> "Ivan Santiago" <isantiago at ogp.pr.gov> escribió:
>  Hello:
>> Run
>> SELECT PostGIS_full_version();
>> TO know if your installation has GEOS 3.3.0 or above.
> I get this
> "POSTGIS="2.0.0 r9605" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March
> 2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
> LIBJSON="UNKNOWN" TOPOLOGY RASTER"
>> Iván Santiago
>> GIS Specialist
>> Information Technologies
>> Office of Management and Budget
>> 787.725.9420 x 2378
>> Calle Cruz 254
>> PO Box 9023228
>> San Juan, PR 00902-3228
>> http://gis.pr.gov
>> -----Original Message-----
>> From: postgis-users-bounces at lists.osgeo.org [mailto:
>> postgis-users-bounces at lists.osgeo.org] On Behalf Of
>> Sent: Friday, May 16, 2014 11:24 AM
>> To: postgis-users at lists.osgeo.org
>> Subject: [postgis-users] problem with st_makevalid and (LineString)
>> Hello people, i got a problem where i have no idea what can i do.
>> I have this table
>> CREATE TABLE ft_potencial
>>    id_dw_ft_potencial integer NOT NULL,
>>    id_dw_tipo integer NOT NULL,
>>    id_dw_mes integer NOT NULL,
>>    id_dw_municipio integer NOT NULL,
>>    id_dw_date integer NOT NULL,
>>    potencial real NOT NULL,
>>    area real NOT NULL,
>>    the_geom geometry(Polygon,4326),
>>    CONSTRAINT ft_potencial_pkey PRIMARY KEY (id_dw_ft_potencial,
>> id_dw_tipo, id_dw_mes, id_dw_municipio, id_dw_date)
>> WITH (
>>    OIDS=FALSE
>> and i want to clean  the errors that it has using the function
>> ST_MakeValid in this way
>> update ft_potencial set the_geom=ST_MakeValid(the_geom);
>> but it always return this error
>> ERROR:  Geometry type (LineString) does not match column type (Polygon)
>> ********** Error **********
>> Estado SQL:22023
>> what can i do to fix or clean the geometry without problems.
>> please help.
>> thanks
>> This message was sent using IMP, the Internet Messaging Program.
>> Este mensaje le ha llegado mediante el servicio de correo electronico que
>> ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema
>> Nacional de Salud. La persona que envia este correo asume el compromiso de
>> usar el servicio a tales fines y cumplir con las regulaciones establecidas
>> Infomed: http://www.sld.cu/
>> postgis-users mailing list
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140516/38799113/attachment.html>
