[postgis-users] problem with st_makevalid and (LineString)
Rémi Cura
remi.cura at gmail.com
Sat May 17 02:44:55 PDT 2014
Hm,
you have a table with polygons.
Obviously some of the polygons are not valid.
So when you correct some of the polygon, they are transformed to line (my
guess : some of the polygons are wihtout surface, for instance POLYGON((0 0
, 1 1 , 0 0 )) ).
Now when trying to insert line into polygon column, postgres complains.
You can do 2 things :
_solve the postgres error, this imply to be sure to update with polygons
_solve the geometry problem, this imply to look a bit into your data to
understand why you have invalid polygon in the first place ..;
The query I gave you is going to show the invalid polygon and why they are
invalid (solving 2.).
If you just don't care, you can update only when the result is a
polygon.(this querry is suboptimal)
UPDATE ft_potencial SETthe_geom=ST_MakeValid(the_geom)
WHERE GeometryType(ST_MakeValid(the_geom) ) ILIKE '%POLYGON%';
Cheers,
Remi-C
2014-05-16 23:58 GMT+02:00 <islanis at infomed.sld.cu>:
> "Rémi Cura" <remi.cura at gmail.com> escribió:
> Remi i dont understand what do you mean here,
> You can try to analyze a bit to understand better
>> (for the following I consider your table doesn't contains too much data)
>> with the_data AS (
>> SELECT the_geom, ST_ISValid(the_geom) AS is_valid,
>> ST_IsValidReason(the_geom)
>> FROM ft_potencial
>> SELECT *, ST_AsText(ST_MakeValid(the_geom)) AS corrected_geom,
>> ST_AsText(the_geom) AS original_geometry, detail.*
>> FROM the_data, *ST_IsValidDetail*(the_geom) AS detail
>> WHERE is_valid = false
>> AND GeometryType(the_geom) ILIKE '%POLYGON%'
>> My guess : you have an invalid no-area polygon, so the makevalid function
>> transform it into a line
> ok, but like i say above, i dont understan, please be more specific,
> please, but thanks
>> Cheers,
>> Rémi-C
>> 2014-05-16 18:14 GMT+02:00 <islanis at infomed.sld.cu>:
>>> "Ivan Santiago" <isantiago at ogp.pr.gov> escribió:
>>> Hello:
>>>> Run
>>>> SELECT PostGIS_full_version();
>>>> TO know if your installation has GEOS 3.3.0 or above.
>>>> I get this
>>> "POSTGIS="2.0.0 r9605" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March
>>> 2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
>>> LIBJSON="UNKNOWN" TOPOLOGY RASTER"
>>>> Iván Santiago
>>>> GIS Specialist
>>>> Information Technologies
>>>> Office of Management and Budget
>>>> 787.725.9420 x 2378
>>>> Calle Cruz 254
>>>> PO Box 9023228
>>>> San Juan, PR 00902-3228
>>>> http://gis.pr.gov
>>>> -----Original Message-----
>>>> From: postgis-users-bounces at lists.osgeo.org [mailto:
>>>> postgis-users-bounces at lists.osgeo.org] On Behalf Of
>>>> Sent: Friday, May 16, 2014 11:24 AM
>>>> To: postgis-users at lists.osgeo.org
>>>> Subject: [postgis-users] problem with st_makevalid and (LineString)
>>>> Hello people, i got a problem where i have no idea what can i do.
>>>> I have this table
>>>> CREATE TABLE ft_potencial
>>>> id_dw_ft_potencial integer NOT NULL,
>>>> id_dw_tipo integer NOT NULL,
>>>> id_dw_mes integer NOT NULL,
>>>> id_dw_municipio integer NOT NULL,
>>>> id_dw_date integer NOT NULL,
>>>> potencial real NOT NULL,
>>>> area real NOT NULL,
>>>> the_geom geometry(Polygon,4326),
>>>> CONSTRAINT ft_potencial_pkey PRIMARY KEY (id_dw_ft_potencial,
>>>> id_dw_tipo, id_dw_mes, id_dw_municipio, id_dw_date)
>>>> WITH (
>>>> OIDS=FALSE
>>>> and i want to clean the errors that it has using the function
>>>> ST_MakeValid in this way
>>>> update ft_potencial set the_geom=ST_MakeValid(the_geom);
>>>> but it always return this error
>>>> ERROR: Geometry type (LineString) does not match column type (Polygon)
>>>> ********** Error **********
>>>> Estado SQL:22023
>>>> what can i do to fix or clean the geometry without problems.
>>>> please help.
>>>> thanks
>>>> This message was sent using IMP, the Internet Messaging Program.
>>>> Este mensaje le ha llegado mediante el servicio de correo electronico
>>>> que
>>>> ofrece Infomed para respaldar el cumplimiento de las misiones del
>>>> Sistema
>>>> Nacional de Salud. La persona que envia este correo asume el compromiso
>>>> de
>>>> usar el servicio a tales fines y cumplir con las regulaciones
>>>> establecidas
>>>> Infomed: http://www.sld.cu/
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>> Este mensaje le ha llegado mediante el servicio de correo electronico que
>>> ofrece Infomed para respaldar el cumplimiento de las misiones del Sistema
>>> de
>>> establecidas
> Nacional de Salud. La persona que envia este correo asume el compromiso de
> usar el servicio a tales fines y cumplir con las regulaciones establecidas
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140517/5a98ae42/attachment.html>
