[postgis-users] Restoring a dump
Jason Mathis jmathis at redzonesoftware.com
Mon May 19 14:14:58 PDT 2014
Are you getting that error on the postgis_restore.pl?
If yes I am not sure about that one I will leave it up to the pros. I think there is a bug open somewhere about this issue…Basically its calling a function (to create the constraint) that is in another schema not the one you are restoring to and the call is not fully qualified.
In the past with raster tables I have had to go this route:
restore schema only
drop all raster constraints for each table http://postgis.net/docs/RT_DropRasterConstraints.html
restore the data
add all raster constants back for each table http://postgis.net/docs/RT_AddRasterConstraints.htm
I actually had to create a separate script to run through my tables because we have about 25-30 raster tables.
On May 19, 2014 at 3:02:32 PM, Jayson Gallardo (jaysontrades at gmail.com) wrote:
Yes. The database has rasters. I just tried loading rtpostgis.sql, etc., but none of those seemed to help at all. I did load legacy.sql before the dump as well.
On Mon, May 19, 2014 at 3:54 PM, Jason Mathis <jmathis at redzonesoftware.com> wrote:
Do you have raster columns/tables?
On May 19, 2014 at 2:47:47 PM, Jayson Gallardo (jaysontrades at gmail.com) wrote:
So, I finally got around to running the restore, but I get this following error:
ERROR:  function st_bandmetadata(public.raster, integer[]) does not exist
Any ideas?
On Mon, May 19, 2014 at 12:29 PM, Jason Mathis <jmathis at redzonesoftware.com> wrote:
What do you mean, starting from scratch? You have to install postgresql/postgis and then follow the answers/links from sandro. You should be good with that dump.
good luck!
On May 19, 2014 at 10:22:38 AM, Jayson Gallardo (jaysontrades at gmail.com) wrote:
Here's the thing, all I have is a dump (postgres_dump_03172014.gz) using pg_dumpall. The server has been reformatted with a clean install of Debian. I haven't even installed Postgres yet. So, what are my options then? I really would hate to start from scratch.
On Mon, May 19, 2014 at 10:15 AM, Sandro Santilli <strk at keybit.net> wrote:
On Mon, May 19, 2014 at 09:39:20AM -0500, Jayson Gallardo wrote:
> Hey, all. So, we recently re-did our server. We were previously running
> Ubuntu, and now we are running Debian. I had performed a pg_dumpall on our
> Postgres database (with PostGIS) and would now like to restore said dump.
> However, I want to make sure I do it right.
Follow the instructions here:
http://postgis.net/docs/manual-2.1/postgis_installation.html#hard_upgrade
> Since I dumped everything, will I need to create all the databases before
> restoring the dump?
> I should probably install the Postgis plug-in first, right?
You should create the databases and spatially-enable them
(could be a chance to switch to EXTENSION-based install).
> My dump is pretty big at 101 GB (it contains 3m resolution DEMs of Iowa).
> Is there anything I need to do in order to minimize errors in the restore?
I guess you could reinstall each database separately, to at least
be more in control of what fails ...
--strk;
 ()  ASCII ribbon campaign  --  Keep it simple !
 /\  http://strk.keybit.net/rants/ascii_mails.txt
postgis-users mailing list
postgis-users at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
This transmission contains confidential and privileged information intended solely for the party identified above. If you receive this message in error, you must not use it or convey it to others. Please destroy it immediately and contact the sender at (303) 386-3955 or by return e-mail to the sender.
the sender.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140519/c5effd13/attachment.html>
