[postgis-users] Restoring a dump
Bborie Park
dustymugs at gmail.com
Mon May 19 15:24:33 PDT 2014
Jayson,
Too late now but you generally don't want to use pg_dumpall as that dumps a
database cluster (all databases and catalog data) into one text (SQL) file.
You may need to go down this nasty road...
1. Set up a clean postgresql server
2. Use psql to restore the database cluster to that new server
3. Dump your databases individually using pg_dump and the custom file
format ("-F c")
4. On your final database server, restore each database using pg_restore. I
usually extract the backup from the custom file format to a text file as I
have to modify the search_path parameter to include my schema layout.
-bborie
On Mon, May 19, 2014 at 3:11 PM, Jayson Gallardo <jaysontrades at gmail.com>wrote:
> We have about that many raster sources that are tiled into the database. I
> would like to try your suggestion, however when I run pg_restore it tells
> me that my dump is text format and that I should use psql. I don't see an
> option for psql to do a restore schema only.
> On Mon, May 19, 2014 at 4:14 PM, Jason Mathis <jmathis at redzonesoftware.com
> > wrote:
>> Are you getting that error on the postgis_restore.pl?
>> If yes I am not sure about that one I will leave it up to the pros. I
>> think there is a bug open somewhere about this issue…Basically its calling
>> a function (to create the constraint) that is in another schema not the one
>> you are restoring to and the call is not fully qualified.
>> In the past with raster tables I have had to go this route:
>> 1. restore schema only
>> 2. drop all raster constraints for each table
>> http://postgis.net/docs/RT_DropRasterConstraints.html
>> 3. restore the data
>> 4. add all raster constants back for each table
>> http://postgis.net/docs/RT_AddRasterConstraints.htm
>> I actually had to create a separate script to run through my tables
>> because we have about 25-30 raster tables.
>> On May 19, 2014 at 3:02:32 PM, Jayson Gallardo (jaysontrades at gmail.com)
>> wrote:
>> Yes. The database has rasters. I just tried loading rtpostgis.sql,
>> etc., but none of those seemed to help at all. I did load legacy.sql before
>> the dump as well.
>> On Mon, May 19, 2014 at 3:54 PM, Jason Mathis <
>> jmathis at redzonesoftware.com> wrote:
>>> Do you have raster columns/tables?
>>> On May 19, 2014 at 2:47:47 PM, Jayson Gallardo (jaysontrades at gmail.com)
>>> wrote:
>>> So, I finally got around to running the restore, but I get this
>>> following error:
>>> ERROR: function st_bandmetadata(public.raster, integer[]) does not exist
>>> Any ideas?
>>> On Mon, May 19, 2014 at 12:29 PM, Jason Mathis <
>>>> What do you mean, starting from scratch? You have to install
>>>> postgresql/postgis and then follow the answers/links from sandro. You
>>>> should be good with that dump.
>>>> good luck!
>>>> On May 19, 2014 at 10:22:38 AM, Jayson Gallardo (jaysontrades at gmail.com)
>>>> wrote:
>>>> Here's the thing, all I have is a dump (postgres_dump_03172014.gz)
>>>> using pg_dumpall. The server has been reformatted with a clean install of
>>>> Debian. I haven't even installed Postgres yet. So, what are my options
>>>> then? I really would hate to start from scratch.
>>>> On Mon, May 19, 2014 at 10:15 AM, Sandro Santilli <strk at keybit.net>wrote:
>>>>> On Mon, May 19, 2014 at 09:39:20AM -0500, Jayson Gallardo wrote:
>>>>> > Hey, all. So, we recently re-did our server. We were previously
>>>>> running
>>>>> > Ubuntu, and now we are running Debian. I had performed a pg_dumpall
>>>>> on our
>>>>> > Postgres database (with PostGIS) and would now like to restore said
>>>>> dump.
>>>>> > However, I want to make sure I do it right.
>>>>> Follow the instructions here:
>> http://postgis.net/docs/manual-2.1/postgis_installation.html#hard_upgrade
>> > Since I dumped everything, will I need to create all the databases
>>>>> before
>>>>> > restoring the dump?
>>>>> > I should probably install the Postgis plug-in first, right?
>>>>> You should create the databases and spatially-enable them
>>>>> (could be a chance to switch to EXTENSION-based install).
>>>>> > My dump is pretty big at 101 GB (it contains 3m resolution DEMs of
>>>>> Iowa).
>>>>> > Is there anything I need to do in order to minimize errors in the
>>>>> restore?
>>>>> I guess you could reinstall each database separately, to at least
>>>>> be more in control of what fails ...
>>>>> --strk;
>>>>> () ASCII ribbon campaign -- Keep it simple !
>>>>> /\ http://strk.keybit.net/rants/ascii_mails.txt
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>> This transmission contains confidential and privileged information
>>>> intended solely for the party identified above. If you receive this message
>>>> in error, you must not use it or convey it to others. Please destroy it
>>>> immediately and contact the sender at (303) 386-3955 or by return
>>>> e-mail to the sender.
>> immediately and contact the sender at (303) 386-3955 or by return e-mail
>> to the sender.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140519/8887bf02/attachment.html>
