[postgis-users] Restoring a dump
Bborie Park dustymugs at gmail.com
Mon May 19 15:38:09 PDT 2014
Pulling things out of thin air here but is your PostGIS installed in a
separate schema? It makes me wonder as to the "public" schema in
"st_bandmetadata(public.raster,
integer[])".
-bborie
On Mon, May 19, 2014 at 3:34 PM, Jayson Gallardo <jaysontrades at gmail.com>wrote:
> Well, the the thing is psql is what's initially giving me the error
> that function st_bandmetadata(public.raster, integer[]) does not exist.
> Would it be okay to let the restore continue even with those errors? I
> just simply want all the data back into a database so I can get our webapp
> back online.
> Our data is static, so I don't see the benefit of dumping each database
> individually. I only did this since we were having issues upgrading
> Postgres and PostGIS, along with other Ubuntu issues.
> Thanks for all the help. I will start afresh tomorrow morning.
> Cheers,
> Jayson
> On Mon, May 19, 2014 at 5:24 PM, Bborie Park <dustymugs at gmail.com> wrote:
>> Jayson,
>> Too late now but you generally don't want to use pg_dumpall as that dumps
>> a database cluster (all databases and catalog data) into one text (SQL)
>> file. You may need to go down this nasty road...
>> 1. Set up a clean postgresql server
>> 2. Use psql to restore the database cluster to that new server
>> 3. Dump your databases individually using pg_dump and the custom file
>> format ("-F c")
>> 4. On your final database server, restore each database using pg_restore.
>> I usually extract the backup from the custom file format to a text file as
>> I have to modify the search_path parameter to include my schema layout.
>> -bborie
>> On Mon, May 19, 2014 at 3:11 PM, Jayson Gallardo <jaysontrades at gmail.com>wrote:
>>> We have about that many raster sources that are tiled into the database.
>>> I would like to try your suggestion, however when I run pg_restore it tells
>>> me that my dump is text format and that I should use psql. I don't see an
>>> option for psql to do a restore schema only.
>>> On Mon, May 19, 2014 at 4:14 PM, Jason Mathis <
>>> jmathis at redzonesoftware.com> wrote:
>>>> Are you getting that error on the postgis_restore.pl?
>>>> If yes I am not sure about that one I will leave it up to the pros. I
>>>> think there is a bug open somewhere about this issue…Basically its calling
>>>> a function (to create the constraint) that is in another schema not the one
>>>> you are restoring to and the call is not fully qualified.
>>>> In the past with raster tables I have had to go this route:
>>>>    1. restore schema only
>>>>    2. drop all raster constraints for each table
>>>>    http://postgis.net/docs/RT_DropRasterConstraints.html
>>>>    3. restore the data
>>>>    4. add all raster constants back for each table
>>>>    http://postgis.net/docs/RT_AddRasterConstraints.htm
>>>> I actually had to create a separate script to run through my tables
>>>> because we have about 25-30 raster tables.
>>>> On May 19, 2014 at 3:02:32 PM, Jayson Gallardo (jaysontrades at gmail.com)
>>>> wrote:
>>>>  Yes. The database has rasters. I just tried loading rtpostgis.sql,
>>>> etc., but none of those seemed to help at all. I did load legacy.sql before
>>>> the dump as well.
>>>> On Mon, May 19, 2014 at 3:54 PM, Jason Mathis <
>>>>>  Do you have raster columns/tables?
>>>>> On May 19, 2014 at 2:47:47 PM, Jayson Gallardo (jaysontrades at gmail.com)
>>>>> wrote:
>>>>>   So, I finally got around to running the restore, but I get this
>>>>> following error:
>>>>> ERROR:  function st_bandmetadata(public.raster, integer[]) does not
>>>>> exist
>>>>> Any ideas?
>>>>> On Mon, May 19, 2014 at 12:29 PM, Jason Mathis <
>>>>>>  What do you mean, starting from scratch? You have to install
>>>>>> postgresql/postgis and then follow the answers/links from sandro. You
>>>>>> should be good with that dump.
>>>>>>  good luck!
>>>>>> On May 19, 2014 at 10:22:38 AM, Jayson Gallardo (
>>>>>> jaysontrades at gmail.com) wrote:
>>>>>>  Here's the thing, all I have is a dump (postgres_dump_03172014.gz)
>>>>>> using pg_dumpall. The server has been reformatted with a clean install of
>>>>>> Debian. I haven't even installed Postgres yet. So, what are my options
>>>>>> then? I really would hate to start from scratch.
>>>>>> On Mon, May 19, 2014 at 10:15 AM, Sandro Santilli <strk at keybit.net>wrote:
>>>>>>> On Mon, May 19, 2014 at 09:39:20AM -0500, Jayson Gallardo wrote:
>>>>>>> > Hey, all. So, we recently re-did our server. We were previously
>>>>>>> running
>>>>>>> > Ubuntu, and now we are running Debian. I had performed a
>>>>>>> pg_dumpall on our
>>>>>>> > Postgres database (with PostGIS) and would now like to restore
>>>>>>> said dump.
>>>>>>> > However, I want to make sure I do it right.
>>>>>>> Follow the instructions here:
>>>> http://postgis.net/docs/manual-2.1/postgis_installation.html#hard_upgrade
>>>>   > Since I dumped everything, will I need to create all the databases
>>>>>>> before
>>>>>>> > restoring the dump?
>>>>>>> > I should probably install the Postgis plug-in first, right?
>>>>>>> You should create the databases and spatially-enable them
>>>>>>> (could be a chance to switch to EXTENSION-based install).
>>>>>>> > My dump is pretty big at 101 GB (it contains 3m resolution DEMs of
>>>>>>> Iowa).
>>>>>>> > Is there anything I need to do in order to minimize errors in the
>>>>>>> restore?
>>>>>>> I guess you could reinstall each database separately, to at least
>>>>>>> be more in control of what fails ...
>>>>>>> --strk;
>>>>>>>  ()  ASCII ribbon campaign  --  Keep it simple !
>>>>>>>  /\  http://strk.keybit.net/rants/ascii_mails.txt
>>>>>>> _______________________________________________
>>>>>>> postgis-users mailing list
>>>>>>> postgis-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>>> This transmission contains confidential and privileged information
>>>>>> intended solely for the party identified above. If you receive this message
>>>>>> in error, you must not use it or convey it to others. Please destroy it
>>>>>> immediately and contact the sender at (303) 386-3955 or by return
>>>>>> e-mail to the sender.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140519/976fe523/attachment.html>
