[postgis-users] psycopg : web service
dandrigo lcelati at latitude-geosystems.com
Tue May 20 08:49:47 PDT 2014
Dear all,
I would like code a web service with python. I have already imported
several vector data (land cover) and one Digital Elevation Model
(raster layer) into my postgresql/postgis database (server side).
I succeed in connecting to my pg db via psycopg2 (postgresql 's python api)
Client side, operators use a client application (Developed with PHP /
javascript / openlayers).
Objectives :  Client side, once the layer would be selected,and once
the operators have clicked on the map  , they would like that usefull
informations appear on the interface of the client application(kind of
land cover, z of the DEM).
=> Regarding my python script, i have to type a SQL query in order to
select usefull informations of the db layers. And, of course, the
information must  depend on geographic coordinates (Latitude
Y/Longitute X).
In a 2nd time, my script must  produce a result(JSon type) for the
client side.
It would be possible to help me regarding the coding in order to
select usefull informations of the db layers. (depends on geographic
coordinates x/y  ? Could you throw light for me regarding the way to
do this SQL query ?
In advance, thank you to throw light for me.
View this message in context: http://postgis.17.x6.nabble.com/psycopg-web-service-tp5006366.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
