[postgis-users] SRID not matching error
Jayson Gallardo
jaysontrades at gmail.com
Wed May 21 16:04:23 PDT 2014
I was finally able to restore my database dump today. However, upon
testing, I get this error:
production=# SELECT ST_AsGDALRaster(ST_CLIP(ST_Union(rast),
ST_GeomFromText('POLYGON((-10366992.073461 5117898.5805526,-10366635.506271
5117898.5805526,-10366635.506271 5118206.0551587,-10366992.073461
5118206.0551587,-10366992.073461 5117898.5805526))',3857)),'GTiff') FROM
"dem_elevation" WHERE ST_Intersects(rast,
ST_Transform(ST_GeomFromText('POLYGON((-10366992.073461
5117898.5805526,-10366635.506271 5117898.5805526,-10366635.506271
5118206.0551587,-10366992.073461 5118206.0551587,-10366992.073461
5117898.5805526))',3857),4269));
NOTICE: Geometry provided does not have the same SRID as the raster.
Returning NULL
However, all my DEMs are in the raster with SRID 4269. My DEMs have been
partitioned however, but the restore should have restored all that back
into place, right?
This is what I have for dem_elevation in pgAdmin:
-- Table: dem_elevation
-- DROP TABLE dem_elevation;
CREATE TABLE dem_elevation
rid integer NOT NULL,
rast raster,
CONSTRAINT dem_elevation_pkey PRIMARY KEY (rid)
WITH (
OIDS=FALSE
ALTER TABLE dem_elevation
OWNER TO postgres;
GRANT ALL ON TABLE dem_elevation TO postgres;
GRANT SELECT, REFERENCES, TRIGGER ON TABLE dem_elevation TO postgis_reader;
And one of the dependents:
-- Table: dem_elevation_n33w090
-- DROP TABLE dem_elevation_n33w090;
CREATE TABLE dem_elevation_n33w090
rid serial NOT NULL,
rast raster,
CONSTRAINT dem_elevation_n33w090_pkey PRIMARY KEY (rid),
CONSTRAINT enforce_height_rast CHECK (st_height(rast) = 50),
CONSTRAINT enforce_max_extent_rast CHECK
(st_coveredby(st_convexhull(rast),
'0103000020AD1000000100000005000000863D2B1A098056C03B126100F5FE3F40863D2B1A098056C09578563412804040CA451840BD3F56C09578563412804040CA451840BD3F56C03B126100F5FE3F40863D2B1A098056C03B126100F5FE3F40'::geometry)),
CONSTRAINT enforce_num_bands_rast CHECK (st_numbands(rast) = 1),
CONSTRAINT enforce_out_db_rast CHECK (_raster_constraint_out_db(rast) =
'{f}'::boolean[]),
CONSTRAINT enforce_pixel_types_rast CHECK
(_raster_constraint_pixel_types(rast) = '{32BF}'::text[]),
CONSTRAINT enforce_same_alignment_rast CHECK (st_samealignment(rast,
'010000000097C6CEA0C845183F97C6CEA0C84518BF863D2B1A098056C0957856341280404000000000000000000000000000000000AD10000001000100'::raster)),
CONSTRAINT enforce_scalex_rast CHECK (st_scalex(rast)::numeric(16,10) =
0.000092592592593::numeric(16,10)),
CONSTRAINT enforce_scaley_rast CHECK (st_scaley(rast)::numeric(16,10) =
(-0.000092592592593)::numeric(16,10)),
CONSTRAINT enforce_srid_rast CHECK (st_srid(rast) = 4269),
CONSTRAINT enforce_width_rast CHECK (st_width(rast) = 50)
INHERITS (dem_elevation)
WITH (
OIDS=FALSE
ALTER TABLE dem_elevation_n33w090
OWNER TO postgres;
GRANT ALL ON TABLE dem_elevation_n33w090 TO postgres;
GRANT SELECT, REFERENCES, TRIGGER ON TABLE dem_elevation_n33w090 TO
postgis_reader;
-- Index: dem_elevation_n33w090_rast_gist
-- DROP INDEX dem_elevation_n33w090_rast_gist;
CREATE INDEX dem_elevation_n33w090_rast_gist
ON dem_elevation_n33w090
USING gist
(st_convexhull(rast));
Thanks for your help in advance,
Jayson
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20140521/c2c03353/attachment.html>
