[postgis-users] Difference between "Geometry" and "BLOB" in Postgis
Robert Burgholzer rburghol at vt.edu
Sat Nov 1 07:45:56 PDT 2014
Damn right man - thanks!
On Saturday, November 1, 2014, Sandro Santilli <strk at keybit.net> wrote:
> On Fri, Oct 31, 2014 at 05:12:40PM -0400, Robert Burgholzer wrote:
> > So just for accuracy, I was incorrect, sort of.  While the functions
> that I
> > am currently using "contains, within, ..." will do the CAST implicitly,
> the
> > GIST index does not like the bytea type.  Which makes the adoption of an
> > actual geometry column even more urgent.
> For further accuracy, you might pass the GiST index an expression, then
> it'll like it. Example:
>  create index on mytable using gist (geometry(mybytea));
>  explain select gid from mytable where mybytea && ST_MakeEnvelope(0,0,1,1);
> --strk;
> postgis-users mailing list
> postgis-users at lists.osgeo.org <javascript:;>
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
Robert W. Burgholzer
 'Making the simple complicated is commonplace; making the complicated
simple, awesomely simple, that's creativity.'  - Charles Mingus
Athletics: http://athleticalgorithm.wordpress.com/
Science: http://robertwb.wordpress.com/
Wine: http://reesvineyard.wordpress.com/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141101/702124a4/attachment.html>
