[postgis-users] Import gpx files into Postgis db (windows)?
James David Smith
james.david.smith at gmail.com
Tue Nov 4 02:23:54 PST 2014
Thank you very much Nicholas. I will try this later. :-)
On Tue Nov 04 2014 at 10:21:14 Nicolas Ribot <nicolas.ribot at gmail.com>
wrote:
> Hi James,
> I don't know well the GPX format, but it seems several types of geo
> objects can be stored (waypoints, routes, tracks, route_points,
> track_points).
> OGR will read each of these layers and create a postgis table for them:
> ogrinfo command lists the layers:
> $ ogrinfo sample.gpx
> Had to open data source read-only.
> INFO: Open of `sample.gpx'
> using driver `GPX' successful.
> 1: waypoints (Point)
> 2: routes (Line String)
> 3: tracks (Multi Line String)
> 4: route_points (Point)
> 5: track_points (Point)
> (with -al -so switches, you get details of each layer)
> To load the file in a PG database:
> ogr2ogr -f PostgreSQL PG:"dbname=test" sample.gpx
> 5 tables corresponding to the layers will be created.
> The PG:"..." part is used to configure the database connection (port,
> username, password, ...)
> test=# \dt
> Liste des relations
> Schéma | Nom | Type | Propriétaire
> public | route_points | table | nicolas
> public | routes | table | nicolas
> public | spatial_ref_sys | table | nicolas
> public | track_points | table | nicolas
> public | tracks | table | nicolas
> public | waypoints | table | nicolas
> (6 lignes)
> Nicolas
> On 4 November 2014 10:52, James David Smith <james.david.smith at gmail.com>
> wrote:
>> Hi Nicolas,
>> Thanks for pointing Dandrigo towards the GPX driver for GDAL - I
>> didn't know it existed to be honest so saw your reply with interest.
>> Would you mind, if possible, giving a sample line or two about how
>> someone could create a new table in PostGIS from the GPX please? The
>> examples in the documentation aren't that clear (or perhaps I just
>> don't understand them!).
>> Regards
>> James
>> On 3 November 2014 08:06, Nicolas Ribot <nicolas.ribot at gmail.com> wrote:
>> > Hello,
>> > You can use GDAL/OGR, (ogr2ogr): http://www.gdal.org/drv_gpx.html
>> > Nicolas
>> > On 31 October 2014 18:32, dandrigo <lcelati at latitude-geosystems.com>
>> wrote:
>> >> Dear all,
>> >> I'm working with windows 8 & postgis 2.1.
>> >> I have several gps (gpx) files. I would like to import directly those
>> gpx
>> >> files into my postgis database.
>> >> What would be the easiest way?
>> >> In advance, thank you to throw light for me.
>> >> Regards.
>> >> View this message in context:
>> http://postgis.17.x6.nabble.com/Import-gpx-files-into-Postgis-db-windows-tp5007255.html
>> >> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> postgis-users mailing list
>> >> postgis-users at lists.osgeo.org
>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141104/6863aed4/attachment.html>
