[postgis-users] FileGDB curves
Rémi Cura remi.cura at gmail.com
Wed Nov 12 08:15:15 PST 2014
So it seems you are stuck with approximating curve with line inside FileGDB
before using ogr.
I guess you can do so using arcgis, but I never used it.
Cheers,
Rémi-C
2014-11-12 17:09 GMT+01:00 Paul Ramsey <pramsey at cleverelephant.ca>:
> Correct, the curves were likely ruined on the way through GDAL. In
> some ways, fortunate they ever got through at all.
> On Wed, Nov 12, 2014 at 7:48 AM, Bborie Park <dustymugs at gmail.com> wrote:
> > If I remember correctly, curve geometries are not currently supported in
> > GDAL/OGR. There is a GDAL RFC making the rounds for adding curve
> support...
> > http://trac.osgeo.org/gdal/wiki/rfc49_curve_geometries
> > -bborie
> > On Wed, Nov 12, 2014 at 7:44 AM, Andy Colson <andy at squeakycode.net>
> wrote:
> >> Shoot.  I changed the command to:
> >> ogr2ogr
> >>   -f PostgreSQL
> >>   -t_srs EPSG:3857
> >>   'PG:dbname=gis'
> >>   WCWebDataCC.gdb
> >>   -lco FID=gid
> >>   -lco SPATIAL_INDEX=OFF
> >>   -lco GEOMETRY_NAME=the_geom
> >>   -lco SCHEMA=washingtonmn
> >>   -lco PRECISION=NO
> >>   streets
> >> (removing the -nlt) and I still get a MULTILINESTRING, and it still
> looks
> >> the same.
> >> The ogr2ogr is part of a perl script, and the first command I posted was
> >> my guess at what it generated, which was a little off.  The command
> above is
> >> correct.
> >> I'm not sure what else to try.
> >> -Andy
> >> _______________________________________________
> >> postgis-users mailing list
> >> postgis-users at lists.osgeo.org
> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141112/507cf451/attachment.html>
