[postgis-users] Returning polygons if any of a polygon input points lie in the polygons
    Rémi Cura
    remi.cura at gmail.com
    Tue Nov 18 03:20:52 PST 2014
Something like this?
SELECT  zone,gid,state,name,ST_Asgeojson( geom )
FROM polys
WHERE ST_Overlaps(ST_GeomFromText('POLYGON((-109 42,-108 42, -108 43; -109
43, -109 42))', 4269), geom)=TRUE;
Cheers,
Rémi-C
2014-11-18 9:00 GMT+01:00 Hugues François <hugues.francois at irstea.fr>:
> Hello,
> Maybe I don’t understand your problem very well but I think your query for
> points should work with a polygon using ST_GeomFromText (
> http://www.postgis.org/docs/ST_GeomFromText.html) for your input polygon
> or a subquery if it stored into your DB.
> Hugues.
> *De :* postgis-users-bounces at lists.osgeo.org [mailto:
> postgis-users-bounces at lists.osgeo.org] *De la part de* Joseph Spenner
> *Envoyé :* lundi 17 novembre 2014 22:35
> *À :* PostGIS Users Discussion
> *Objet :* [postgis-users] Returning polygons if any of a polygon input
> Hello, I'm trying to perform a query which will return any polygons which
> have any points in common with an input polygon.
> So, if I have Polygon A.
> In my database, I have several other polygons stored.
> I want to submit a query with Polygon A as the input, which will return
> all of the polygons in my database which have any points in common with
> Polygon A.
> Can this be done?
> I found this:
> http://postgis.net/docs/ST_Overlaps.html
> But from what I can tell, it only returns a T or F.   I need to fetch the
> actual polygons if T.
> I'm currently able to query with points as input:
> select zone,gid,state,name,ST_Asgeojson( geom ) from polys where
> ST_Intersects(ST_PointFromText('POINT(-109 42)', 4269), geom);
> But now I have a need to use polygons as input.
> Any help would be great.
> Thanks!
> Regards,
> Joseph Spenner
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141118/06aa5a67/attachment.html>
