[postgis-users] Creating trajectory/lines from millions of points[PostGIS]
Brent Wood
pcreso at pcreso.com
Tue Nov 25 00:53:46 PST 2014
or automatically get the start & end times for each trackline in the record like this:
WITH multis AS ( SELECT id, min(time_field) AS time_start, max(time_field) as time_end, status, ST_MakeLine(array_agg(point_geom )) AS mylines FROM your_tableGROUP BY id, statusORDER BY time_field) SELECT id, status, (ST_Dump(mylines)).geomFROM multis;
Cheers, Brent Wood
From: Hugues François <hugues.francois at irstea.fr>
To: PostGIS Users Discussion <postgis-users at lists.osgeo.org>
Sent: Tuesday, November 25, 2014 8:13 PM
Subject: Re: [postgis-users] Creating trajectory/lines from millions of points[PostGIS]
#yiv8453726355 #yiv8453726355 -- _filtered #yiv8453726355 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv8453726355 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;}#yiv8453726355 #yiv8453726355 p.yiv8453726355MsoNormal, #yiv8453726355 li.yiv8453726355MsoNormal, #yiv8453726355 div.yiv8453726355MsoNormal {margin:0cm;margin-bottom:.0001pt;font-size:12.0pt;}#yiv8453726355 a:link, #yiv8453726355 span.yiv8453726355MsoHyperlink {color:blue;text-decoration:underline;}#yiv8453726355 a:visited, #yiv8453726355 span.yiv8453726355MsoHyperlinkFollowed {color:purple;text-decoration:underline;}#yiv8453726355 p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;}#yiv8453726355 span.yiv8453726355EmailStyle18 {color:#1F497D;}#yiv8453726355 .yiv8453726355MsoChpDefault {} _filtered #yiv8453726355 {margin:70.85pt 70.85pt 70.85pt 70.85pt;}#yiv8453726355 div.yiv8453726355WordSection1 {}#yiv8453726355 Hello, In your case I would have try to make multilines for each taxi and each status (i.e. two multi by taxi) and then dump them into simple linestrings. All in a query that may look like this assuming you have a taxi id field: WITH multis AS ( SELECT id, status, ST_MakeLine(array_agg(point_geom )) AS mylines FROM your_tableGROUP BY id, statusORDER BY time_field) SELECT id, status, (ST_Dump(mylines)).geomFROM multis You may want to add a time reference to your lines. To do this, you can add an extraction from your timestamp field (e.g. day or month) and add it into the WITH and to the group by clause. Hugues. De : postgis-users-bounces at lists.osgeo.org [mailto:postgis-users-bounces at lists.osgeo.org] De la part de Oliver Burgfeld
Envoyé : mardi 25 novembre 2014 07:09
À : postgis-users at lists.osgeo.org
Objet : [postgis-users] Creating trajectory/lines from millions of points[PostGIS]
Hi,I have millions of points in a PostGIS database containing taxi gps tracks. Now I want to create lines from these points by vehicleid and ordered by timestamp. But, and that's my problem right now, at first I want to include every column of my point table into the "line table" and I also need to intersect those lines at specific points.I have one column representing the "taxi_is_occupied" status with 0 or 1. What I want now is to create lines which are divided every time this status changes. In the end I need lines which show the path of every taxi over time, divided every time the status of the car changes so that I can query all lines where the taxi is occupied, for example.What do I have to use therefore? I know that there is the ST_MakeLines tool existing in PostGIS, but as I am a new PostGIS user... I do not know exactly how to use it to get the results I need. Thanks a lot
postgis-users mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141125/3d5265c8/attachment.html>
