[postgis-users] Creating trajectory/lines from millions of points[PostGIS]
Oliver Burgfeld oliver.burgfeld at gmail.com
Tue Nov 25 08:10:25 PST 2014
Thank you and all the others who were answering :)
I tried that and it seems that its working. Nevertheless I only tried it
with a small part of my data (round about 1 million rows out of ~500
million) but if it's working now, it should also work with the whole
dataset.
Is there a way to also include the time_field into the result? I created a
new table with this statement given but there are only two columns
(vehicleid and status) included.
I know thats logical because I only included those two into my select
clause but it would be great to not only order by time but also have a time
column in my table.
For example:
vehicleid | status | time_start | time_end
I hope its understandable and not to mixed up...
Thanks!
Am Dienstag, 25. November 2014 16:06:33 UTC+1 schrieb Rémi Cura:
> Hey, a small correction :
> ST_MakeLine is already an aggregate, and you may want to enforce the order
> inside the aggregate (see at the end).
> Another interesting point is the possiblity to pu somehting in the M value
> of each point of the line, for instance the time.
> This comes very handy when you want to extrat parts of the lines.
> So for instance for the first proposition :
> WITH multis AS (
>                 SELECT id, status,* ST_MakeLine( point_**geom ORDER BY
> time_field) *AS mylines
>                 FROM your_table
> GROUP BY id, status
> SELECT id, status, (ST_Dump(mylines)).geom
> FROM multis
> Cheers,
> Rémi-c
> 2014-11-25 9:53 GMT+01:00 Brent Wood <pcr... at pcreso.com <javascript:>>:
>> or automatically get the start & end times for each trackline in the
>> record like this:
>> WITH multis AS (
>>                 SELECT id, min(time_field) AS time_start, max(time_field)
>> as time_end, status, ST_MakeLine(array_agg(point_geom )) AS mylines
>>                 FROM your_table
>> GROUP BY id, status
>> ORDER BY time_field
>> FROM multis;
>> Cheers,
>>    Brent Wood
>>  *From:* Hugues François <hugues.... at irstea.fr <javascript:>>
>> *To:* PostGIS Users Discussion <postgi... at lists.osgeo.org <javascript:>>
>> *Sent:* Tuesday, November 25, 2014 8:13 PM
>> *Subject:* Re: [postgis-users] Creating trajectory/lines from millions
>> of points[PostGIS]
>> Hello,
>> In your case I would have try to make multilines for each taxi and each
>> status (i.e. two multi by taxi) and then dump them into  simple
>> linestrings. All in a query that may look like this assuming you have a
>> taxi id field:
>> WITH multis AS (
>>                 SELECT id, status, ST_MakeLine(array_agg(point_geom )) AS
>> mylines
>>                 FROM your_table
>> GROUP BY id, status
>> ORDER BY time_field
>> FROM multis
>> You may want to add a time reference to your lines. To do this, you can
>> add an extraction from your timestamp field (e.g. day or month) and add it
>> into the WITH and to the group by clause.
>> Hugues.
>> *De :* postgis-us... at lists.osgeo.org <javascript:> [mailto:
>> postgis-us... at lists.osgeo.org <javascript:>] *De la part de* Oliver
>> Burgfeld
>> *Envoyé :* mardi 25 novembre 2014 07:09
>> *À :* postgi... at lists.osgeo.org <javascript:>
>> *Objet :* [postgis-users] Creating trajectory/lines from millions of
>> points[PostGIS]
>> Hi,
>> I have millions of points in a PostGIS database containing taxi gps
>> tracks. Now I want to create lines from these points by vehicleid and
>> ordered by timestamp. But, and that's my problem right now, at first I want
>> to include every column of my point table into the "line table" and I also
>> need to intersect those lines at specific points.
>> I have one column representing the "taxi_is_occupied" status with 0 or 1.
>> What I want now is to create lines which are divided every time this
>> status changes. In the end I need lines which show the path of every taxi
>> over time, divided every time the status of the car changes so that I can
>> query all lines where the taxi is occupied, for example.
>> What do I have to use therefore? I know that there is the ST_MakeLines
>> tool existing in PostGIS, but as I am a new PostGIS user... I do not know
>> exactly how to use it to get the results I need.
>> Thanks a lot
>> postgis-users mailing list
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141125/e36a05dc/attachment-0001.html>
