[postgis-users] Creating trajectory/lines from millions of points[PostGIS]
Oliver Burgfeld
oliver.burgfeld at gmail.com
Tue Nov 25 08:48:03 PST 2014
I also tried that and it works but it does not give me those two columns in
my new table. There are only id and status inside.
Am Dienstag, 25. November 2014 17:39:21 UTC+1 schrieb Brent Wood:
> as in my previous reply, I figured that would be useful...
> WITH multis AS (
> SELECT id, status,* min(timestamp) as time_start,
> max(timestamp) as time_end, *ST_MakeLine( point_geom ORDER BY timestamp) AS
> mylines
> FROM your_table
> GROUP BY id, status
> SELECT id, status, (ST_Dump(mylines)).geom
> FROM multisBrent Wood
> *From:* Oliver Burgfeld <oliver.... at gmail.com <javascript:>>
> *To:* postgi... at googlegroups.com <javascript:>
> *Cc:* pcr... at pcreso.com <javascript:>; postgi... at lists.osgeo.org
> <javascript:>; postgi... at lists.osgeo.org <javascript:>; remi... at gmail.com
> <javascript:>
> *Sent:* Wednesday, November 26, 2014 5:10 AM
> *Subject:* Re: [postgis-users] Creating trajectory/lines from millions of
> points[PostGIS]
> Thank you and all the others who were answering :)
> I tried that and it seems that its working. Nevertheless I only tried it
> with a small part of my data (round about 1 million rows out of ~500
> million) but if it's working now, it should also work with the whole
> dataset.
> Is there a way to also include the time_field into the result? I created a
> new table with this statement given but there are only two columns
> (vehicleid and status) included.
> I know thats logical because I only included those two into my select
> clause but it would be great to not only order by time but also have a time
> column in my table.
> For example:
> vehicleid | status | time_start | time_end
> I hope its understandable and not to mixed up...
> Thanks!
> Am Dienstag, 25. November 2014 16:06:33 UTC+1 schrieb Rémi Cura:
> Hey, a small correction :
> ST_MakeLine is already an aggregate, and you may want to enforce the order
> inside the aggregate (see at the end).
> Another interesting point is the possiblity to pu somehting in the M value
> of each point of the line, for instance the time.
> This comes very handy when you want to extrat parts of the lines.
> So for instance for the first proposition :
> WITH multis AS (
> SELECT id, status,* ST_MakeLine( point_**geom ORDER BY
> time_field) *AS mylines
> FROM your_table
> GROUP BY id, status
> FROM multis
> Cheers,
> Rémi-c
> 2014-11-25 9:53 GMT+01:00 Brent Wood <pcr... at pcreso.com>:
> or automatically get the start & end times for each trackline in the
> record like this:
> WITH multis AS (
> SELECT id, min(time_field) AS time_start, max(time_field)
> as time_end, status, ST_MakeLine(array_agg(point_ geom )) AS mylines
> FROM your_table
> GROUP BY id, status
> ORDER BY time_field
> FROM multis;
> Cheers,
> Brent Wood
> *From:* Hugues François <hugues.... at irstea.fr>
> *To:* PostGIS Users Discussion <postgi... at lists.osgeo.org >
> *Sent:* Tuesday, November 25, 2014 8:13 PM
> points[PostGIS]
> Hello,
> In your case I would have try to make multilines for each taxi and each
> status (i.e. two multi by taxi) and then dump them into simple
> linestrings. All in a query that may look like this assuming you have a
> taxi id field:
> WITH multis AS (
> SELECT id, status, ST_MakeLine(array_agg(point_ geom )) AS
> mylines
> FROM your_table
> GROUP BY id, status
> ORDER BY time_field
> FROM multis
> You may want to add a time reference to your lines. To do this, you can
> add an extraction from your timestamp field (e.g. day or month) and add it
> into the WITH and to the group by clause.
> Hugues.
> *De :* postgis-us... at lists. osgeo.org [mailto:postgis-us...@
> lists.osgeo.org] *De la part de* Oliver Burgfeld
> *Envoyé :* mardi 25 novembre 2014 07:09
> *À :* postgi... at lists.osgeo.org
> *Objet :* [postgis-users] Creating trajectory/lines from millions of
> points[PostGIS]
> Hi,
> I have millions of points in a PostGIS database containing taxi gps
> tracks. Now I want to create lines from these points by vehicleid and
> ordered by timestamp. But, and that's my problem right now, at first I want
> to include every column of my point table into the "line table" and I also
> need to intersect those lines at specific points.
> I have one column representing the "taxi_is_occupied" status with 0 or 1.
> What I want now is to create lines which are divided every time this
> status changes. In the end I need lines which show the path of every taxi
> over time, divided every time the status of the car changes so that I can
> query all lines where the taxi is occupied, for example.
> What do I have to use therefore? I know that there is the ST_MakeLines
> tool existing in PostGIS, but as I am a new PostGIS user... I do not know
> exactly how to use it to get the results I need.
> Thanks a lot
> ______________________________ _________________
> postgis-users mailing list
> http://lists.osgeo.org/cgi- bin/mailman/listinfo/postgis- users
> <http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141125/fbdb8ca2/attachment-0001.html>
