[postgis-users] PLPGSQL Function to Calculate Bearing
Rémi Cura
remi.cura at gmail.com
Tue Nov 25 10:33:43 PST 2014
Great, I'm happy for you ;-)
Cheers,
Rémi-C
2014-11-25 18:11 GMT+01:00 Paul & Caroline Lewis <paulcaz80 at hotmail.com>:
> Hi Rémi,
> Thanks for the help here.
> Got it solved based on your suggestions through both SQL and plpgsql.
> So good to learn!!
> Regards,
> Paul
> Date: Mon, 24 Nov 2014 19:34:58 +0100
> From: remi.cura at gmail.com
> To: postgis-users at lists.osgeo.org
> Subject: Re: [postgis-users] PLPGSQL Function to Calculate Bearing
> Hey,
> first you don't need plpgsql for this, you can do it with windows
> functions (
> http://www.postgresql.org/docs/current/static/functions-window.html)
> for the following I assume you have some order available on your point
> data, the order is stored in "id" column :
> CREATE TABLE my_azimuth_data AS
> SELECT id, wgs_geom --, ST_X(wgs_geom), ST_Y(wgs_geom), ST_Z(wgs_geom) --
> X,Y,Z seems unecessary
> FROM points_table
> WHERE ST_Within(points_table.wgs_geom, ST_GeomFromtext('POLYGON...',4326)
> = TRUE
> ORDER BY id ASC ;
> SELECT *, ST_Azimuth(wgs_geom,lead(wgs_geom) OVER (ORDER BY id ASC) ) AS
> my_azimuth
> FROM my_azimuth_data
> ORDER BY id ASC
> --note : you may need to deal with the last row, because it has nothing
> after it , so I don't know what it's azymuth should be...
> now if you really want to use plpgsql :
> DROP FUNCTION IF EXISTS get_bearings_from_points();
> CREATE OR REPLACE FUNCTION get_bearings_from_points()
> RETURNS TABLE(id int, ogeom geometry, my_azimuth double) AS
> $BODY$
> DECLARE
> r record ; --generic type, will hold any row
> old_point geometry := NULL; --we store the value of previous
> geometry
> BEGIN
> FOR r IN
> SELECT *
> FROM my_azimuth_data --loop on the point
> ORDER BY id ASC
> LOOP
> --note : you may want to deal with the first row in a peculiar
> fashion
> id := r.id; --filling the output row
> ogeom:= r.wgs_geom ;
> my_azimuth := ST_Azimuth(old_point, r.wgs_geom) ;
> old_point := r.wgs_geom ; --updating the old_point with new
> value for next iteration
> RETURN NEXT; --outputing the row
> END LOOP;
> RETURN;
> END
> $BODY$
> LANGUAGE plpgsql;
> If you are more familiar with python you may benefit from using pl/pythonu.
> Cheers,
> Rémi-C
> 2014-11-24 18:33 GMT+01:00 Paul & Caroline Lewis <paulcaz80 at hotmail.com>:
> Basically I can't get my head around the syntax of plpgsql and would
> appreciate some help with the following efforts.
> I have a table containing 1000's of wgs84 points. The following SQL will
> retrieve a set of points within a bounding box on this table:
> SELECT id, ST_X(wgs_geom), ST_Y(wgs_geom), ST_Z(wgs_geom) FROM
> points_table INNER JOIN (SELECT
> ST_Transform(ST_GeomFromText('POLYGON((-1.73576102027
> 51.5059743629,-1.73591122397 51.5061067655,-1.73548743495
> 51.5062838333,-1.73533186682 51.5061514313,-1.73576102027
> 51.5059743629))',4326),) AS bgeom) AS t2 ON ST_Within(local_geom, t2.bgeom)
> What I need to do is add a bearing/azimuth column to the results that
> describes the bearing at each point in the returned data set.
> So the approach I'm trying to implement is to build a plpgsql function
> that can select the data as per above and calculate the bearing between
> each set of points in a loop.
> However my efforts at understanding basic data access and handling within
> a plpgsql function are failing miserably.
> An example of the current version of the function I'm trying to create is
> as follows:
> CREATE TYPE bearing_type AS (x numeric, y numeric, z numeric, bearing
> numeric);
> RETURNS SETOF bearing_type AS
> $BODY$
> DECLARE
> rowdata points_table%rowtype;
> returndata bearing_type;
> BEGIN
> FOR rowdata IN
> SELECT nav_id, wgs_geom FROM points_table INNER JOIN (SELECT
> 53.5059743629,-1.73591122397 53.5061067655,-1.73548743495
> 53.5062838333,-1.73533186682 53.5061514313,-1.73576102027
> 53.5059743629))',4326),27700) AS bgeom) AS t2 ON ST_Within(local_geom,
> t2.bgeom)
> LOOP
> returndata.x := ST_X(rowdata.wgs_geom);
> returndata.y := ST_Y(rowdata.wgs_geom);
> returndata.z := ST_Z(rowdata.wgs_geom);
> returndata.bearing := ST_Azimuth(<current_point> ,
> <next_point>)
> RETURN NEXT returndata;
> END LOOP;
> RETURN;
> END
> $BODY$
> LANGUAGE plpgsql;
> I should just be able to call this function as follows:
> SELECT get_bearings_from_points();
> and get the desired result.
> Basically the problems are understanding how to access the rowdata
> properly such that I can read the current and next points.
> In the above example I've had various problems from how to call the ST_X
> etc SQL functions and have tried EXECUTE select statements with errors re
> geometry data types.
> Thanks
> Paul
> Any insights/help would be much appreciated
> postgis-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
> _______________________________________________ postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141125/88570d6a/attachment.html>
