[postgis-users] NOTICE: no non-null/empty features, unable to compute statistics
Paul Ramsey pramsey at cleverelephant.ca
Wed Oct 1 15:26:16 PDT 2014
Well, trying to synthetically reproduce your error is not working.
Butterfly:~/Code/postgis-svn/postgis pramsey$ vacuumdb -v -Z -d postgis22 -t pts
INFO:  analyzing "public.pts"
INFO:  "pts": scanned 14286 of 14286 pages, containing 1000000 live
rows and 0 dead rows; 30000 rows in sample, 1000000 estimated total
rows
I used a basic random table,
CREATE TABLE pts AS
WITH rands AS (
  SELECT generate_series as id, random() AS u1, random() AS u2 FROM
generate_series(1,1000000)
SELECT
  id,
  ST_SetSRID(ST_MakePoint(
    50 * sqrt(-2 * ln(u1)) * cos(2*pi()*u2),
    50 * sqrt(-2 * ln(u1)) * sin(2*pi()*u2),
sin(2*pi()*u2)),4326)::Geometry(PointZM,4326) AS geom
FROM rands;
P
On Tue, Sep 23, 2014 at 3:54 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> I guess in theory I could reproduce it with some random xyz data...
> P
> On Tue, Sep 23, 2014 at 1:47 PM, Jason Mathis
> <jmathis at redzonesoftware.com> wrote:
>> So unfortunately I did not get the go ahead to share the data, but I solved
>> the problem. It was a dataset that was merged from several different
>> datasets which is why I got the “PointZM” from shp2pgsql. I was given a
>> shape file to load into the database. Although the data just needed to be
>> two dimensional. I also had the original coordinates, so I drop the column
>> and re-added with just “POINT” and updated the geometry from the lat/longs
>> and viola no “notice” message.
>> Is it only an issue with three or four dimensional data?
>> Thanks,
>> jason
>> On September 22, 2014 at 5:43:43 PM, Paul Ramsey (pramsey at cleverelephant.ca)
>> wrote:
>> If you can share data, I'm happy to try and reproduce it here.
>> P
>> On Mon, Sep 22, 2014 at 2:01 PM, Jason Mathis
>>> I am stumped on it. I think i remember seeing something like this before,
>>> but can’t quite recall.
>>> Queries both return zero.
>>> 'POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
>>> March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.6"
>>> LIBJSON="UNKNOWN" RASTER'
>>> i even tried putting a bogus null row in there but I still got the
>>> message.
>>> thanks!
>>> On September 22, 2014 at 2:52:00 PM, Paul Ramsey
>>> wrote:
>>> It means it sampled 30000 rows and didn't find any geometries that
>>> were non-null or non-empty. I suppose it could mean a bug, though that
>>> code's been around for a while.
>>> select count(*) from yourtable where geom is null;
>>> select count(*) from yourtable where st_isempty(geom);
>>> select postgis_full_version();
>>> P.
>>> On Mon, Sep 22, 2014 at 12:11 PM, Jason Mathis
>>>> Does anyone know what this “notice” means? I loaded some new data into a
>>>> table from a shape file.Visually it looks good and loaded without error.
>>>> I
>>>> have a nightly analyze job that runs and since loading the data it spits
>>>> out
>>>> this “notice” I don’t know what it means. If I drop the geom column I do
>>>> not
>>>> get this message. I have tried drop/create the index, and reloading the
>>>> data without success.
>>>> Thanks!
>>>> $ /usr/bin/vacuumdb -v -Z -d redzone -t 'demo.homes'
>>>> INFO: analyzing "demo.homes"
>>>> INFO: "homes": scanned 2237 of 2237 pages, containing 101937 live rows
>>>> and
>>>> 0 dead rows; 30000 rows in sample, 101937 estimated total rows
>>>> CREATE TABLE demo.homes
>>>> gid integer NOT NULL DEFAULT nextval('demo.homes_gid_seq'::regclass),
>>>> geolat numeric,
>>>> geolong numeric,
>>>> geolevel text,
>>>> geonumber integer,
>>>> geostreet text,
>>>> geocity text,
>>>> geocounty text,
>>>> geostate text,
>>>> zip text,
>>>> firstname text,
>>>> lastname text,
>>>> tiv integer,
>>>> geom geometry(PointZM,4326),
>>>> CONSTRAINT homes_pkey PRIMARY KEY (gid)
>>>> This transmission contains confidential and privileged information
>>>> intended
>>>> solely for the party identified above. If you receive this message in
>>>> error,
>>>> you must not use it or convey it to others. Please destroy it immediately
>>>> and contact the sender at (303) 386-3955 or by return e-mail to the
>>>> sender.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>> intended
>>> error,
>>> sender.
>> This transmission contains confidential and privileged information intended
>> solely for the party identified above. If you receive this message in error,
>> and contact the sender at (303) 386-3955 or by return e-mail to the sender.
