[postgis-users] reverse_geocode() specific error at specific geom point
Paragon Corporation
lr at pcorp.us
Mon Oct 6 20:16:27 PDT 2014
Barry,
I don't have North Carolina data loaded in my db -- what happens if you run
the below query the debug outputs -- does it error or give you results.
Gives me nothing and reverse geocode just gives me North Carolina since I
don't have NC state data loaded.
If it does and returns results then I suspect the issue is it's trying to
cast the address number part to a number,and its probably blank or not a
number.
Though I thought I had safeguards for that.
Which postgis geocoder version are you working with, and which tiger data
set. I had upgraded PostGIS 2.2 to use Tiger 2014 but hadn't finished doing
testing on it.
Thanks,
Regina
http://www.postgis.us
http://postgis.net
_____
[mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Barry McCall
Sent: Monday, October 06, 2014 6:03 PM
To: postgis-users at lists.osgeo.org
Subject: [postgis-users] reverse_geocode() specific error at specific geom
point
For some reason when I reverse_geocode geometry point
0101000020AD10000095D4096822CC53C08A1F63EE5AAA4140
it returns error
ERROR: invalid input syntax for type numeric: " "
********** Error **********
SQL state: 22P02
I performed UPDATE tiger.geocode_settings SET setting = 'true' WHERE name =
'debug_reverse_geocode'; to try to get a grasp of what was going on;
however, there are so many CTEs in the debug I cant get a grasp of what is
really happening.
Does anyone familiar with this system know why this is throwing this error?
It seems to only happen with lon,lat around -79.1866 35.3309.
SELECT r.addy[1] FROM reverse_geocode(ST_GeomFromText('POINT(-79.1866
35.3309)',4269),true) AS r
NOTICE: Statement 1:
WITH ref AS (
SELECT
'0101000020AD10000095D4096822CC53C08A1F63EE5AAA4140'::geometry As ref_geom )
f AS
( SELECT faces.* FROM faces CROSS JOIN ref
WHERE faces.statefp = '37' AND faces.countyfp = '105'
AND ST_Intersects(faces.the_geom, ref_geom)
e AS
( SELECT edges.tlid , edges.statefp, edges.the_geom, CASE WHEN edges.tfidr =
f.tfid THEN 'R' WHEN edges.tfidl = f.tfid THEN 'L' ELSE NULL END::varchar As
eside,
ST_ClosestPoint(edges.the_geom,ref_geom) As center_pt,
ref_geom
FROM edges INNER JOIN f ON (f.statefp = edges.statefp AND (edges.tfidr =
f.tfid OR edges.tfidl = f.tfid))
CROSS JOIN ref
WHERE edges.statefp = '37' AND edges.countyfp = '105'
AND ST_DWithin(edges.the_geom, ref.ref_geom, 0.01) AND (edges.mtfcc LIKE
'S%') --only consider streets and roads
ea AS
(SELECT e.statefp, e.tlid, a.fromhn, a.tohn, e.center_pt, ref_geom, a.zip,
a.side, e.the_geom
FROM e LEFT JOIN addr As a ON (a.statefp = '37' AND e.tlid = a.tlid and
e.eside = a.side)
SELECT *
FROM (SELECT DISTINCT ON(tlid,side) foo.fullname, foo.streetname,
foo.streettypeabbrev, foo.zip, foo.center_pt,
side, to_number(fromhn, '999999') As fromhn, to_number(tohn, '999999') As
tohn, ST_GeometryN(ST_Multi(line),1) As line,
dist
FROM
(SELECT e.tlid, e.the_geom As line, n.fullname, COALESCE(n.prequalabr || '
','') || n.name <http://n.name/>
AS streetname, n.predirabrv, COALESCE(suftypabrv, pretypabrv) As
streettypeabbrev,
n.sufdirabrv, e.zip, e.side, e.fromhn, e.tohn , e.center_pt,
ST_Distance_Sphere(ST_SetSRID(e.center_pt,4326),ST_SetSRID(ref_geom,4326))
As dist
FROM ea AS e
LEFT JOIN (SELECT featnames.* FROM featnames
WHERE featnames.statefp = '37' ) AS n ON (n.statefp = e.statefp AND
n.tlid = e.tlid)
ORDER BY dist LIMIT 50 ) As foo
ORDER BY foo.tlid, foo.side, CASE 0 WHEN 0 THEN 0 WHEN 1 THEN CASE WHEN
foo.fullname ~ '[0-9]+' THEN 0 ELSE 1 END ELSE CASE WHEN foo.fullname > ''
AND NOT (foo.fullname ~ '[0-9]+') THEN 0 ELSE 1 END END , foo.fullname ASC
NULLS LAST, dist LIMIT 50) As f ORDER BY f.dist, CASE WHEN fullname > ''
THEN 0 ELSE 1 END
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20141006/5bc12d68/attachment.html>
